Author Topic: Honda CB750k clutch  (Read 1205 times)
Offline Pauarc
Honda CB750k clutch
« on: May 01, 2023, 10:08:02 AM »
Any help can you do the clutch without draining the oil
Cb750k2
Re: Honda CB750k clutch
« Reply #1 on: May 01, 2023, 10:39:58 AM »
Should be fine even on centre stand, but side will tip it away from the opening.
Virtually all the oil should be in the tank on 750, with just residual in the sump.  That's assuming the check valves etc working OK.
Use a drip tray as you'll get a little come out if it's been run recently, but nothing much usually.
Offline Pauarc
« Reply #2 on: May 01, 2023, 11:14:52 AM »
Thanks for the answer only just put new oil in and the clutch still not working properly the gears clunk when changing gear so want to check plates and don’t want to waste the oil
Cb750k2
Offline Martin6
« Reply #3 on: May 01, 2023, 12:13:56 PM »
Expect you have checked, but could be the adjustment at the clutch end? 1/4 to 1/2 out with a loosened off clutch cable (both ends).
« Reply #4 on: May 01, 2023, 01:29:13 PM »
What 750K clutch ? I think the K6 has a double plate and 6 or 7 different clutches fitted to 750K's.
Offline Pauarc
« Reply #5 on: May 01, 2023, 03:26:07 PM »
My bike is a Honda CB750k2 1975 I have done all adjustments but haven’t looked at the clutch plate yet
Cb750k2
Offline Pauarc
« Reply #6 on: May 01, 2023, 03:31:47 PM »
My CB750k2
Cb750k2
« Reply #7 on: May 01, 2023, 05:20:43 PM »
Nice looking bike! Twin disc conversion too.👍
1978 Honda CB550K3.
« Reply #8 on: May 01, 2023, 05:35:25 PM »
Does your VIN number start with 21*****? I'm trying to pin down exactly what model it is to try and work out what clutch it may have in it. Is it a USA model or a UK model?
Offline Pauarc
« Reply #9 on: May 02, 2023, 12:12:27 PM »
Frame no cb750 2098725
Engine no cb750e 2382187
Uk reg 1975
Cb750k2
« Reply #10 on: May 02, 2023, 03:13:37 PM »
Have you considered doing the clutch basket mod? involves drilling more holes to allow more oil to reach the plates.
« Reply #11 on: May 02, 2023, 04:02:52 PM »
Can you elaborate on that Ken, new one on me that. Cheers.
« Reply #12 on: May 02, 2023, 04:28:15 PM »
I think you'll find the later 750's are already drilled as standard, I'm 99% certain the K6's are but unsure of where through the era of K2's (in the UK model range) they started doing that from the factory. I'll have to ask Graham.
« Reply #13 on: May 02, 2023, 05:08:35 PM »
One other thing, if you're adjusting the clutch as per manual, the manual is wrong. It says turn the adjuster in and then in another ¼-½ in, that's incorrect. It's turn it out by that much.
« Reply #14 on: May 02, 2023, 06:15:54 PM »
This may explain it Roy, there was a much more detailed post on it but as yet I haven't found it, if I do I'll post a link.
http://forums.sohc4.net/index.php?topic=10454.0
Also this. Which may have been the one I spotted.
http://forums.sohc4.net/index.php/topic,7190.0.html
