Author Topic: CB750 Wiring Issues  (Read 3534 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
Re: CB750 Wiring Issues
« Reply #60 on: May 18, 2023, 08:41:12 AM »
Whatever else may be wrong with the loom, they certainly gave you enough length; my wires are barely long enough to get into the headlight bucket!
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
« Reply #61 on: May 18, 2023, 09:25:16 AM »
It was as long on the other end, I had to pull it up a bit into the headlight to get the many connections correct behind the side panel. Will have to shorten some of the cables or I won't get the headlight in. Usual pattern parts, they appear to go to a lot of trouble to get it wrong. Bewildering really, it's as easy to get it right as wrong.
Sent from my Pixel 7 Pro using Tapatalk
« Reply #62 on: May 18, 2023, 11:34:17 AM »
The brown/white is for the small park light, which is not fitted in US but is actualy a legal requirement in UK as according to construction and use/mot it is an obligatory light, unlike the headlamp which doesnt have to be there but if it is it must work.
Good old english lawmakers, no sense, no idea
« Reply #63 on: May 18, 2023, 03:30:04 PM »
That means then that the front parking light will be on whenever the rear light is on, ie when riding at night. That can't be right?
« Reply #64 on: May 18, 2023, 03:32:59 PM »
Every vehicle I have owned has the front side lamp illuminated when the rear lamp is on including when the headlamp is on dip or main. I believe the law calls them positional lamps.
Only DTRL's have changed that slightly - some dim at night etc.
« Reply #65 on: May 18, 2023, 03:34:18 PM »
Agree with Ted, they are designed to have the side light lit whenever any lights are shown, including as Ted says dip and main.
« Reply #66 on: May 18, 2023, 04:16:51 PM »
Fair point. If only I had a side light.
« Reply #67 on: May 18, 2023, 04:45:25 PM »
A side light my kingdom for a side light I hear someone cry! :P :P :P
« Reply #68 on: May 18, 2023, 07:02:50 PM »
I did wonder about some period looking daytime running lamps for my 750 but never managed to source any.
1978 Honda CB550K3.
« Reply #69 on: July 05, 2023, 09:24:25 AM »
The brown white IS for the front parking light but the yanks use sealed beam headlamps without one .
The orange/white and blue/white are for the front running light in the US front indicators, not legal in UK so leave them loose
