Author Topic: CB550F Speedo Drive  (Read 407 times)
Offline DougP
CB550F Speedo Drive
« on: June 19, 2023, 12:35:06 PM »
Hello all,
Does anyone know what part number oil seal is used in the speedo drive?
Cheers,
Doug
Re: CB550F Speedo Drive
« Reply #1 on: June 19, 2023, 01:06:19 PM »
Hello all,
Cheers,
Doug
Is it the oil seal inside the cable connector shaft you are after or the one inside the hub?
Parts books for the 550 are in Aladdins Cave that are free to dowload.
« Last Edit: June 19, 2023, 01:16:04 PM by McCabe-Thiele (Ted) »
« Reply #2 on: June 19, 2023, 02:06:47 PM »
Someone here will need to confirm the 550 is the same Speedo drive hub as the 500.
On my 500 the seals were: 15x4.8x4 for the cable end.
Hub seal was 34x48x7 a double lipped seal iirs R23/TC.
Both seals available on e bay or similar.
« Reply #3 on: June 19, 2023, 02:26:00 PM »
Same drive, same seals.
Offline mickwinf
« Reply #4 on: June 19, 2023, 04:09:19 PM »
The smaller one i just got off ebay quite cheap. https://www.ebay.co.uk/itm/392573565762
Offline DougP
« Reply #5 on: June 20, 2023, 10:00:57 AM »
Well I think I may as well replace both while it’s on the bench.
The parts manual doesn’t break down the speedo drive assy.
Thanks for the responses guy’s.
« Last Edit: June 20, 2023, 10:04:26 AM by DougP »
« Reply #6 on: June 20, 2023, 02:13:18 PM »
Not sure if you've already dismantled it Doug but if not use a really good screwdriver on the grub screw or it will round off. A little heat might not go astray either if it refuses to move.
Offline DougP
« Reply #7 on: June 20, 2023, 10:54:33 PM »
Will do. Thanks.
