Author Topic: Selling my 550F  (Read 1911 times)
Offline Davelu88
Selling my 550F
« on: July 18, 2023, 12:07:19 PM »
Hi Selling my 75 plate 550F was an import but UK reg now , loads done last year frame & swingarm powder coated , new bronze bushes , new headstock bearings & races , seat , indicators , handle bars , ignition , paint , left side switch gear , plus lots more i have forgot . Has a normal wheel on the rear now and not the wide rim as in the pics i do have some of the other bits that came off it , grab rail fender stays , rear light , it does have a Kerker exhaust which is great & i believe quite expensive . had some new seals in carbs and i put them through the ultrasonic cleaner , tank is mint inside. message if anyone got any questions. £2750
Dave
« Last Edit: September 05, 2023, 03:28:33 PM by Davelu88 »
Offline Davelu88
Re: Selling my 550F
« Reply #1 on: July 19, 2023, 07:58:15 PM »
Reduced to £3000
Re: Selling my 550F
« Reply #2 on: July 19, 2023, 11:12:50 PM »
I have a question Dave : Is the silencer bolted to the swinging arm ?
Re: Selling my 550F
« Reply #3 on: July 20, 2023, 08:45:54 AM »
It looks like it in the photo!
« Last Edit: July 20, 2023, 09:40:10 AM by McCabe-Thiele (Ted) »
Offline Davelu88
Re: Selling my 550F
« Reply #4 on: July 20, 2023, 11:20:26 AM »
Hi , no it is a bracket to bottom of suspension.  :)
Re: Selling my 550F
« Reply #5 on: July 20, 2023, 11:46:44 AM »
So your exhaust moves up & down with the swing arm ?
Must be a very flexible exhaust coupling.
« Last Edit: July 20, 2023, 12:25:54 PM by McCabe-Thiele (Ted) »
Offline Davelu88
Re: Selling my 550F
« Reply #6 on: July 20, 2023, 12:34:56 PM »
To be honest I have never seen it move as I think the movement is minimal,  it has never leaked or  moved at all since I have been riding it  :)
Re: Selling my 550F
« Reply #7 on: July 20, 2023, 12:39:40 PM »
I suspect you have accidentally turned it into a Bobber then!
Offline Moorey
Re: Selling my 550F
« Reply #8 on: July 20, 2023, 01:20:54 PM »
   If everything is tight and there is no flex joint in the exhaust and nothing has fractured yet, then you have been very lucky or used it very little. Re
   think the silencer mounting.
Re: Selling my 550F
« Reply #9 on: July 20, 2023, 01:33:18 PM »
OMG. 🙀🫣
Re: Selling my 550F
« Reply #10 on: July 20, 2023, 01:35:01 PM »
It’s bent the bracket quite nicely. A good firm ride….
Offline Davelu88
Re: Selling my 550F
« Reply #11 on: July 20, 2023, 01:54:54 PM »
Never been a problem and do not forsee one either , everything moves in unison.
Re: Selling my 550F
« Reply #12 on: July 20, 2023, 02:39:23 PM »
I think you are failing to see what the problem is Dave. The swinging arm moves up and down, anything attached to the swinging arm also moves up and down, so as the suspension compresses going over a bump the swinging arm moves up, this means so would the exhaust, it has to. This would then flex the entire exhaust system, causing it to break, mostly likely in the middle where it joins the collector box. If you don't remove that bracket the exhaust will break into 2 parts, there is absolutely no doubt about that. The exhaust should hang from the pillion footrest bracket as that is static. I'd suggest you fix the problem before the exhaust breaks (which you are very lucky if it hasn't already), run a long bracket to the pillion footrest hole instead.
Re: Selling my 550F
« Reply #13 on: July 20, 2023, 02:41:43 PM »
Not trying to be negative about your silencer fitting - frankly I'm amazed that  it has not snapped somewhere between the mounting point and the cylinder head without some sort of sprung ball socket joint.
As your rear suspension moves up and down the rear of the silencer has to move up and down - at the cylinder head it is fixed so something has to flex between those two points.
Offline Davelu88
Re: Selling my 550F
« Reply #14 on: July 20, 2023, 03:16:15 PM »
Point taken , I will make a new bracket to the footrest  ;)
