Author Topic: Doms CB550F1 project  (Read 56912 times)
Re: Doms CB550F1 project
« Reply #375 on: December 03, 2023, 09:29:03 AM »
Look at the back of the arm, on the inside edge near where the cain adjusters are welded on there is a small vent hole drilled into the arm. Clean the hole as it normally gets partially blocked with rust flakes. A small straw or something similar inserted in hole and jiggled whilst shaking the arm will allow the rust to drop out
« Last Edit: December 03, 2023, 09:42:08 AM by Oddjob »
Offline DomP
« Reply #376 on: December 03, 2023, 09:49:30 AM »
I thought there should be a venting hole, must have been powdercoated over, I'll have a look.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #377 on: December 03, 2023, 12:20:09 PM »
None on mine Ken, doesn't look like they've been painted over at there's no evidence.  The most rattly but is the pressed bracing plate that has no vent hole either so I will just drill my own and flush it out
« Last Edit: December 03, 2023, 12:54:04 PM by DomP »
1975 XS650B
Offline DomP
« Reply #378 on: December 03, 2023, 02:51:29 PM »
All cb550 swingarms on Ebay are missing drainage/vent holes, would it be sensible to drill a 3-4mm hole so I can flush the crap out and put cavity wax in?
1975 XS650B
« Reply #379 on: December 03, 2023, 03:48:53 PM »
The CB500 swinging arm certainly has them and it's essentially the same arm.
Offline DomP
« Reply #380 on: December 03, 2023, 04:47:04 PM »
Shall I just pop a couple of holes on each side, wouldn't at the lowest point on the underside be the best place to allow condensation to drain out?
1975 XS650B
« Reply #381 on: December 03, 2023, 05:13:05 PM »
I'll take a pic of the 500 arm, it may be that the hole is there but so blocked and painted over that you can't see it.
Offline DomP
« Reply #383 on: December 03, 2023, 05:58:20 PM »
I'll go out and wire brush it to see if it's there,  why would they put it there and not at the lowest point to allow draining?  Water will pool in the bottoms on those
« Last Edit: December 04, 2023, 07:44:59 PM by DomP »
1975 XS650B
« Reply #384 on: December 04, 2023, 09:16:36 AM »
I'll go other and wire brush it to see if it's there,  why would they put it there and not at the lowest point to allow draining?  Water will pool in the bottoms on those
It could be because if they put the hole in the bottom it could potentially allow water to find it's way in especially when you consider this is directly behind the rear wheel and subjected to the spray thrown off the rear tyre.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #385 on: December 04, 2023, 11:22:13 AM »
I'd do the hole where Honda put it on the 500 Dom, I'm using the same hole to fill both sides with Waxoyl after it's been powder coated, then allowing it to drain out afterwards just leaving the layer of wax behind. Do that every few years and it should outlast me
« Reply #386 on: December 04, 2023, 11:46:31 AM »
Any holes in frames or swingarms are often there to allow the escape of hot gasses during welding. It reduces distortion  I believe.
« Reply #387 on: December 04, 2023, 09:33:43 PM »
Rickman put holes in their frames for the same reason Garath. It was also to allow the nickel solution to drain during the plating process otherwise the frame would rot from the inside out.
1976 Honda 400/4
« Reply #388 on: December 04, 2023, 11:18:22 PM »
The problem though is that the swinging arm, because Honda didn't use seam welding but spot welding which allows moisture to form inside the tubes, this then rusts the tubes from the inside out, hence why you can hear rust flakes tinkling around inside, the holes allow you to get rid of those and also to put something down the tubes to stop any future rot.
« Reply #389 on: December 05, 2023, 09:20:34 AM »
Did Honda put holes in all their frames Ken because I haven't seen any on the 400 frame or was it just the 500/550’s?
1976 Honda 400/4
