Author Topic: 500 cylinder head nuts ?  (Read 497 times)
« on: August 20, 2023, 05:09:06 PM »
Currently sorting out my boxes of various fasteners from when I removed my cylinder head & top covers. Most of my covers had SS Hex head bolts fitted previously.
In a box I marked Cylinder Head Nuts I have 8 flanged flat face M8 nuts, 2 of M8 chrome domed nuts, 4 of SS M8 nuts, 12 of M8 flat washers.
The manual shows 12 of M8 flat faced flanged nuts (90236-300-000) so the SS nuts were probably a substitute for 4 missing ones - not sure where the domed nuts go as I can't see them in the parts book.
The DS price for the flanged nuts is £2.88  each, looking at alternative nuts on e-bay  it appears some M8 nuts have a larger diameter flange so probably would not fit in the recess.
Are there more sensibly priced nuts available that are suitable to replace the originals ?
Lastly the 6 rubber caps that are glued in place - what is the best adhesive to use for these please ?
Re: 500 cylinder head nuts ?
« Reply #1 on: August 20, 2023, 05:25:58 PM »
They should be high tensile steel nuts with a thick washer under them have loads of them on my stock list.
You stick the rubbers head sealing pucks down with a smear of honda bond on the rim of the rubber to the underside only  ;)
« Reply #2 on: August 20, 2023, 05:51:47 PM »
The parts manual picture shows flanged nuts plus washer, although the description makes no mention of the nuts being flanged.
DS show it as a flanged nut.
« Last Edit: August 20, 2023, 05:58:17 PM by McCabe-Thiele (Ted) »
« Reply #3 on: August 20, 2023, 06:06:11 PM »
90236-300-000 is a CB750 part which why would it say its flanged. It is used on many Honda head studs  :o
« Reply #4 on: August 20, 2023, 06:08:16 PM »
I suspect the owner before me put the stainless domed nuts on the outside 4 studs for appearance sake, i know there were a lot of stainless cap screws visible
The nuts should be flanged as Trigger said but not the serated type flange that is common to get only flat flange.
« Reply #5 on: August 20, 2023, 06:17:43 PM »
And are only 60p when you buy them in a big Honda trade pack  ;)
« Reply #6 on: August 20, 2023, 06:21:49 PM »
A much more sensible price is 60p each.
Online Oddjob
« Reply #7 on: August 20, 2023, 09:53:15 PM »
How many do you need Ted, I should have loads lying around..
« Reply #8 on: August 20, 2023, 09:55:35 PM »
Only four Ken.
Online Oddjob
« Reply #9 on: August 20, 2023, 10:09:41 PM »
Ok, I'll see about finding 4 tomorrow.
Online Oddjob
« Reply #10 on: August 21, 2023, 04:57:59 PM »
Found 6 nuts and 12 of the washers for you Ted. Posted tomorrow.
« Reply #11 on: August 21, 2023, 06:13:28 PM »
Thanks Ken you're a star.👍👍👍
