Deano.. I can't see any little brass clip in the ones without circlip fitted. Any ideas please?
Cheers Deano ... I think I know what you mean now .. just needs to get a suitable pick to remove the clip.By the way Ted ... every 400F I have ever owned (4) and seen had the spring loaded flap.
If it was missing Ted the lock would come out everytime you used the key. Buggered if I can make out what you're pushing there John. Is it clearer when the barrel is removed? if so maybe a before and after pic would explain it better.
Looking at the pic John, it looks as though that end plate locks the barrel in place at the bottom, lift the plate and you lift it away from the recess presumably at the bottom and the lock now pulls/slides out. Clever.
