Author Topic: My first project - 1974 CB360 K0  (Read 37516 times)
Re: My first project - 1974 CB360 K0
« Reply #75 on: April 06, 2024, 04:11:09 PM »
I know that feeling, when assembling the frame parts - swing arms , front forks, centre stand, front mudguard, front wheel etc .
I have found it best to leave the rear mudguard, battery box & electric gubbins off the bike just fitting the rear wheel nipped up slightly for stability before fitting the engine in place. Handy to have the front bars in place as well even if no switches are fitted yet.
Its easier to re-fit the engine without wiring looms etc, also easier to fit the carbs and airbox before you fit the battery box & front section of rear mudguard in place I have found with my 400.
We all have our own ways towards the finishing post I guess depending on personal choice & if you have a bike ramp.  My last  jobs are fitting the exhuast system, seat & tank. Nothing worse than finding you have fitted items in place only to have to remove them again to get a part inside the frame etc.
« Last Edit: April 06, 2024, 04:15:32 PM by McCabe-Thiele (Ted) »
Offline Craizeehair
« Reply #76 on: April 10, 2024, 06:48:13 PM »
I wonder if anyone has any tips or tricks to remove the lower suspension rubber bushes from the swing arm??
I’ve tried pressing them out with a couple of sockets, that just resulted in me bending the bolt, tried soaking them and knocking them out with a punch but the little blighters won’t budge!!
Am I resigned to trying to cut them out and trying not to damage anything?
Offline magpie114
    • A.M. Photoblog
« Reply #77 on: April 10, 2024, 07:18:17 PM »
I had the same problem on my 350/4. I had to cut from the centre with a junior hacksaw  to the swing arm mount. The bush could be pressed out then.
Honda CB350F
Honda VFR400
Suzuki 650
Offline Craizeehair
« Reply #78 on: April 10, 2024, 07:23:12 PM »
That was my thinking for next steps but was trying to avoid it if possible!
« Reply #79 on: April 10, 2024, 08:02:49 PM »
I burnt mine out then a hacksaw on the outer sleeve.
« Reply #80 on: April 10, 2024, 08:20:56 PM »
Either drill out or burn out.
« Reply #81 on: April 11, 2024, 06:56:38 AM »
Hacksaw method works for me.👍
1978 Honda CB550K3.
« Reply #82 on: April 11, 2024, 08:44:56 AM »
Is it feasible to drill a few small holes in them to give the remaining rubber a bit of space to flex into when you try to press them out?
« Reply #83 on: April 11, 2024, 09:35:23 AM »
The outer sleeve of the bush tend to corrode and hold onto the swing arm surprisingly well.
Drilling around the rubber will eventually enable the center section to come out.
Once you have a level saw cut on the outer sleeve the gap will then enable it to be drifted out.
On my 400, one pressed out easiy, the other fought me all the way, if I'd had a drill bit of the right size & a Pillar drill I would have used that.
Offline Craizeehair
« Reply #84 on: April 11, 2024, 11:09:32 PM »
Thanks for the suggestions, I have burnt the centres out, tomorrow I will take a hacksaw to the outer sleeve and see if I can get that out without butchering it.
The swing arm bushes were a real struggle but I got there in the end, I will be replacing these with bronze bushes.
The CB360 swing arm has no grease nipple, for those in the know, is it worth fitting one and if so, any recommendations as to how / where and any particular grease nipples to go for? I’ve never fitted one before but happy to have a go, feels like there should be one around the middle of the swingarm?
Offline cbxman
« Reply #85 on: April 12, 2024, 08:33:58 AM »
You might want check this out.  A bit of an upgrade.
http://www.sohc.co.uk/index.php/topic,30072.msg292298.html#msg292298
Hope the link works
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
Offline Craizeehair
« Reply #86 on: April 12, 2024, 09:41:41 AM »
Hope the link works
Jerry
Thank you Jerry,
I’ll have a good read of that later, much appreciated.
Greg
Offline Craizeehair
« Reply #87 on: April 21, 2024, 08:44:20 PM »
I’ve put a few things back on the frame, the swinging arm with new bushes and lower shock bushes, centre stand, handlebars, top and bottom yokes with new tapered roller bearings and rebuilt front forks.
The wiring harness has been cleaned in the ultrasonic and I’ll attempt to fit that next, once it has dried. After that I plan to replace the wheel bearings and brake shoes, front and back then get the wheels back on to make it easier to move around again.
« Last Edit: April 21, 2024, 10:51:36 PM by Craizeehair »
« Reply #88 on: April 21, 2024, 11:42:02 PM »
Even though you might have used an Ultrasonic Bath to clean your loom. I would still use Cillit Bang Limescale Remover on the connections as per NJ's advice on previous posts.
« Last Edit: April 22, 2024, 10:58:46 AM by McCabe-Thiele (Ted) »
Offline Craizeehair
« Reply #89 on: April 22, 2024, 07:25:20 AM »
Thanks Ted, I will do that before it goes back on.
