Author Topic: CB750K7 accelerator pump  (Read 826 times)
Offline TERRIBLEONE
« on: September 26, 2023, 10:47:52 PM »
Long shot. Anyone holding spare parts for pd41a carbs? I need a functioning bowl for the accelerator pump, the one way valve in mine is jammed up and preventing the pump from pumping fuel! Thanks.
« Last Edit: September 26, 2023, 10:49:54 PM by TERRIBLEONE »
Online AshimotoK0
Re: CB750K7 accelerator pump
« Reply #1 on: September 27, 2023, 12:23:17 AM »
Think I have one but will have to check
Online AshimotoK0
« Reply #2 on: October 02, 2023, 02:17:58 PM »
Found this and took it apart again to clean.
Tricky ... you have to drill and tap the centre plastic bit (I tapped it M1.8  ), screw in a tiny screw of same thread,  then extract the valve and clean up the ball and seat.
Yours if you want it for cost of post.
Offline TERRIBLEONE
« Reply #3 on: October 02, 2023, 10:40:11 PM »
Yes please mate, that would be really appreciated. I’ll message you now. Thank you.
