Author Topic: Why are M9 SS 1.25 pitch a 20/30 mm flanged bolts so hard to find  (Read 521 times)
If I have worked the size out correctly the captive headlamp earth nuts on the 400 & 500 are M9 presumably 1.25 pitch thread can anyone point me in the direction of a supplier for some SS bolts?
I had some SS hex headed flange bolts in my stock & could do with a couple more.
« Last Edit: November 30, 2023, 02:12:24 PM by McCabe-Thiele (Ted) »
Re: Why are M9 SS 1.25 pitch a 20 mm flanged bolts so hard to find
« Reply #1 on: November 29, 2023, 09:18:41 PM »
Sure it's M9 Ted ?
I dont know, but highly unusual to come across one....there's one in the cylinder head of XL 500 engine I recall.
« Reply #2 on: November 29, 2023, 09:36:27 PM »
Not good with threads K2-K6  but my calipers show the diameter as 9.06mm on the unthreaded section with a 14mm flanged head.
Offline Matt_Harrington
« Reply #3 on: November 30, 2023, 09:13:49 AM »
Ted, measure the thread section rather than the unthreaded part. The 'outer' dim of the threads is what you want.....
Re: Why are M9 SS 1.25 pitch a 20/30 mm flanged bolts so hard to find
« Reply #4 on: November 30, 2023, 02:41:26 PM »
Mystery is over they must be M10 bolts not M9  as I found a couple of NOS bolts in my stock of 400 bits that came with the bike p/n 93101-100320B - nice shiney chrome.
Looking at the part number using Kens information/logic  on part number construction they must be M10 x 32mm long B stands for chrome.
« Reply #5 on: November 30, 2023, 04:33:52 PM »
Probably "rolled" threads rather than die cut, supposed to be stronger
