SOHC.co.uk Forums > SOHC Singles & Twins
CD175 Sloper centre stand spring
paul G:
found one here when the frame was just in primer
AshimotoK0:
--- Quote from: paul G on February 22, 2024, 04:22:03 PM ---
--- End quote ---
Ash,
Did you send Ian the drawing you did for me as it was spot on ;D
[/quote]
Yes .. so it was well worth doing Paul.
Orcade-Ian:
Hi Paul,
Yes, I got the drawing from Ash and it's spot on as you say. A nice little turning job and I silver soldered the plate on instead of welding and then finished with BZP. We don't have the curved plate either (unobtainium too) I have others from other bikes (GB500 for one) so will experiment till it's right.
Thanks again for the info,
Ian
AshimotoK0:
I can hear the muttering now . "Don't give up the day job Ash :-["
Orcade-Ian:
Wow Ash,
A mind reader too! Is there no end to this man's talents? I've massaged - oops, I mean messaged (bloody spell check - my case comes up next week) Paul G asking for that info. My GB 500 one is pretty close to those dimensions, so I think the lug on the dubious stand is too far away to stretch the OE spring. Using your drawing and some calculated guesswork, I can make something of it.
Thanks again,
Ian
Navigation
[0] Message Index
[*] Previous page
Go to full version
