Author Topic: Rear wheel bearings  (Read 4204 times)
Offline PatM
  • 2001 R1, Triumph 1200 and the little 400/4!
Rear wheel bearings
« on: October 10, 2010, 06:25:41 PM »
Hi
how do you get the 2 rear wheel bearings out-and the spacer? ive removed the bearing retainer ring , after fabricating a tool for the job but they are both inteference fit and wont budge?
PatM
Online SteveD CB500K0
Re: Rear wheel bearings
« Reply #1 on: October 10, 2010, 07:54:30 PM »
I "drifted" mine out from the other side with an old length of pipe and a bloody great hammer  :o
2022 Tiger Sport 660
Offline PatM
« Reply #2 on: October 10, 2010, 09:06:51 PM »
Steve
Im adept with a mallet! - but it cant knock in what is already in- I cant get on the back side of the bearings? the spacer is making it an almost smooth axel-way- that I cant get purchase on anything to whack 'em out. Ive never had a 400 hub apart- in fact this isnt mine, its my Bros- he brought the wheels from someone up 't North who siad they were rebuilt, new rims, stainless spokes etc- but theres no spacer fitted! So we decided to take his old wheel apart- got the retainer out, then where faced with two closed doors, so to speak. Im sure you dont have to muller one of the bearings, to get at the spacer and the back of the other?
« Reply #3 on: October 11, 2010, 07:17:23 AM »
The spacer is held central by three "Tabs," put a bar in and lever it sideways so you can get a drift onto the bearing inner race then beat it out, remove spacer and straighten tabs then beat the other bearing out.
NOTE:- Because you are beating them out by hitting the inner race they MUST be replaced with new and not re-greased as you will have impact damaged the races
Offline PatM
« Reply #4 on: October 11, 2010, 08:42:40 AM »
Brian- Thanks- Ill have a go as you have stated. The reason I
Offline PatM
« Reply #5 on: October 13, 2010, 07:14:34 AM »
All
In conclusion to this..
My Bro came round the other night and said he had arranged for the wheel to go to an local engineering Firm in Bexley that does bike-stuff. Just as weel, as it goes- cos they took his new wheel and old wheel- removed the BN bearings and fitted the old ones- Dave (Bro) had ridden the bike WITHOUT the spacers (both missing) and more importantly- the one in the bearing behind the retaining ring- and boogered it.
 The guy who had sold him the wheels- ''all reconditioned and new bearings fitted, for
Offline Yoshi823
  • Biker to the bone...
« Reply #6 on: October 13, 2010, 11:15:35 AM »
I think that the place in Bexley may well be these people who advertise in Classic MCM magazine... http://engineeringsolutionsuk.com/
While on the subject of this magazine, in the October edition there're a couple of lovely pictures of a CR750 engine...the crank is a polished, balanced & lightened. Reminds me of what I had in my 750F2.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
MIKE550/4
  • Guest
« Reply #7 on: October 13, 2010, 08:44:03 PM »
with mine it helped to heat up the hub  ;)
Offline exvalvesetdabbler
« Reply #8 on: October 14, 2010, 08:15:09 PM »
Warm the hub up with a hot air gun. One way is  to use a metal rod  about 2mm smaller in diameter than the axle with the end ground at a very slight angle and a small step. It's usually enough to nudge the spacer sideways a bit. Keep moving round so that you drift it out straight. As soon as the bearing moves a little the spacer should be able to move sideways a bit more.
When putting the new bearings in, put them in the freezer for a while and grease the outside surface well. Make sure that you only hit only the outside ring when putting new ones in.
Regards
DJW
Offline PatM
« Reply #9 on: October 14, 2010, 09:26:51 PM »
Thanks for all your suggestions and help on this.
The wheel is back on the bike and running well- and looking nice!
But a warning to others- a rebuilt wheel with new bearings may not be as re-built as you think! Brother rode the bike, and ruined the bearing thats normaly got the spall spacer- with disasterous results..
Rgds
PatM
