Author Topic: Silicone Oil Viscosity in Instrument Dampers  (Read 3955 times)
« on: October 25, 2010, 11:58:32 PM »
Any thoughts on my post on the SOHC4 Site?
http://forums.sohc4.net/index.php?topic=78890.0
Ash
« Last Edit: October 27, 2010, 08:29:43 PM by AshimotoK0 »
Offline kent400
Re: Silicon Oil Viscosity in Instrument Dampers
« Reply #1 on: October 26, 2010, 08:22:39 PM »
I use this silicone damping fluid, ebay item number 290489033958. Quite expensive but there's enough to fill dozens of dampers. The instruments should always be stored face up. If you have ever seen a new boxed instrument there's a label on it stating 'store face up'. I have had a few new old stock instruments that have not been stored correctly and the fluid has found it's way onto the face. I've managed to remove the fluid from the face using a spray glass cleaner, the type used for spectacles. Great care is needed but it did make a significant improvement. The effectiveness of this method may depend on the face colour, the particular one I recall had a black face.
It's interesting to note that some instruments of the same still age retain their damping, some don't and without any evidence of leakage onto the face.
« Reply #2 on: October 26, 2010, 08:54:40 PM »
Thanks for that kent
How about this
http://www.turntablebasics.com/silicone.html
Ash
Offline kent400
« Reply #3 on: October 26, 2010, 09:40:19 PM »
Looks like the same product as I use but less money! Clearly someone is making a good profit
Offline steff750
  • THE POWER OF DREAMS
« Reply #4 on: October 27, 2010, 12:44:24 AM »
 ::) i have always used wd-40 (spanner inna can) when ever i have opened up my clocks, come to think of it i use it for everything :-* awesome stuff you gotta love it
« Reply #5 on: October 27, 2010, 12:08:17 PM »
WD40 "Silicone free since 1953" - so not silicone!!!
« Last Edit: October 27, 2010, 08:31:24 PM by AshimotoK0 »
« Reply #6 on: October 27, 2010, 08:29:24 PM »
I have just found in my emporium about 750cc (coincidence!!) of CF 900 Minolta laser fuser silicone oil (dimethyl polysiloxane). Anyone know if its any good for instrument dampers? Would be prepared to give small amounts away free to members if it turns out to be OK. I will have to wait till next week to measure its viscosity.
Heard its also used in breast inplants - Jordan Types need not apply for a free sample!!!!
Ash
« Last Edit: October 27, 2010, 08:34:40 PM by AshimotoK0 »
Offline rigwit
Re: Silicone Oil Viscosity in Instrument Dampers
« Reply #7 on: October 28, 2010, 01:20:01 PM »
Glycerine as is, or can be thinned down with top q white spirit...... pure glycerine avaiable from most reputable pharmacy's and cheap as chips
dib! dib! dib.
