Author Topic: Getting started/project CB350/400f  (Read 3745 times)
Offline johndregg
« on: January 27, 2011, 09:10:40 AM »
I've inherited a basket case CB350four. Its been fitted with a CB400 four engine at some point in its life and has been caf
1960 Lambretta Li225
1959 Lambretta Li230cc
1964 Lambretta Li190cc
1975 Honda CB350 four
1996 Honda VFR750f
a busted mini and a rusty mercedes.
Re: Getting started/project CB350/400f
« Reply #1 on: January 27, 2011, 09:24:49 AM »
Hi John.
I assume that you have a manual? Manuals? (you can never have too many) - we have pdfs if required.
Also, put your location in your profile as it will save all the "Where are you?" posts and you may find someone close!
Steve
2022 Tiger Sport 660
Offline johndregg
« Reply #2 on: January 27, 2011, 09:30:17 AM »
I have no manuals, PDFs are more than welcome!
1996 Honda VFR750f
« Reply #3 on: January 29, 2011, 02:37:47 PM »
Whilst the exhaust is off and the engine cold make sure the cam chain tensioner is working
Offline johndregg
« Reply #4 on: January 29, 2011, 05:21:54 PM »
ok, check the chain tensioner! duly noted. ;D
Is there a mark on the cam indicating which position it should be in when attaching the sprocket? I gather that pistons 1+4 need to be at TDC but the cam?
« Last Edit: January 29, 2011, 05:24:41 PM by johndregg »
1996 Honda VFR750f
« Reply #5 on: January 30, 2011, 09:15:13 AM »
You defo need a manual John...
I'll sort through my pdfs for a 350/400 book (most of mine are 500/550)   8)
« Reply #6 on: January 30, 2011, 10:21:03 AM »
Sorry - not a 350/400 pdf in sight...
However, if you go to www.honda4fun.com they have them all there - pick and chose!
Go to "Materiale" and "Parts Lists" and "Manuali"
Steve
Offline johndregg
« Reply #7 on: January 30, 2011, 10:45:04 AM »
Thanks mate.
1996 Honda VFR750f
Offline johndregg
« Reply #8 on: February 09, 2011, 11:08:28 AM »
Quote
Right i've had a look at this. Its the bolt down by the oil filter housing? I think mines been bodged. The adjusting bolt itself is ok but there is no lock nut, just an oversized nut spinning freely. I have to have another look at it, but i'm pretty sure someone has just ignored this for a lot of years.
Anyone got a pic of what parts should be there?
Progress made: New exhaust valves ground in and fitted.
                     NOS gasket set sourced and bought.
Going to try fitting the head tonight.
« Last Edit: February 09, 2011, 11:14:35 AM by johndregg »
1996 Honda VFR750f
« Reply #9 on: February 10, 2011, 06:43:00 AM »
DONT PUT THE HEAD ON YET if the rensioner is fubared its a bottom end strip to put it right and the engine is a lot lighter with the top off!!
Offline johndregg
« Reply #10 on: February 10, 2011, 08:47:49 AM »
I investigated it last night. What i thought was a bodge was just a loosened off tensioner. When i had a closer look it had the correct lock nut, but the thread for this was covered in road filth, i cleaned it all up fitted the blades and screwed it back in. I believe the tensioner is working.
The manual is terrible about this though, is there a better online resource for tips and tricks with photos?
1996 Honda VFR750f
« Reply #11 on: February 10, 2011, 08:57:47 AM »
Have you tried www.sohc4.net?
Go to http://forums.sohc4.net and type "350 cam chain tensioner rebuild" (or similar) into the search box.
There's strength in depth over there.
