Author Topic: battery  (Read 2373 times)
MIKE550/4
  • Guest
battery
« on: March 21, 2011, 01:37:43 PM »
hi all again
if a bike has been laid up all winter, battery disconnected, does not using the battery cause it damage
gave it a good top up , fully charged it up but nothing when put back onto bike
any tips apart from buy new battery
Offline UK Pete
Re: battery
« Reply #1 on: March 21, 2011, 05:05:09 PM »
Some of the cheaper chinese batterys, are very fussy and need a constant use or at least a trickle charge , or the power zaps right out of them and when totally drained they quite often dont recover, alot of the chargers these days have a battery recovery mode which can sometimes salvage a severely drained battery,
Pete
Offline matthewmosse
Re: battery
« Reply #2 on: March 21, 2011, 05:08:03 PM »
Optimate or similar charger with desulphate function is a well worthwhile invsetment. Other trick if that fails connect it to a good car / bike battery (jump leads pos to pos and neg to neg) then charge the good battery Saved my wifes 250 battery from the skip this winter.
Re: battery
« Reply #3 on: March 22, 2011, 06:41:14 AM »
What you need is a variable output DC voltage supply and wind the volts up till the battery takes some current BUT you need to keep a very close eye on it for at least the first 1 1/2 hours
Re: battery
« Reply #4 on: March 22, 2011, 07:24:20 AM »
Or buy an Optimate (or similar) which is more-or-less what they do.
... but you don't have to watch them  :)
2022 Tiger Sport 660
MIKE550/4
  • Guest
Re: battery
« Reply #5 on: March 22, 2011, 08:15:54 AM »
i have one of these optimate chargers, put it on yesterday and red light has stayed on when first connected , which i have read as fully charged
left it charging for about 3-4 hours put back on bike and nothing ?
is 3-4 hours long enough
what exactly is this desulphication ?
Re: battery
« Reply #6 on: March 22, 2011, 10:34:02 AM »
for an optimate the red lights indicate desulphating, orange is charging and green is good to go (at least on mine) It can take a day or more to do it's thing.
Re: battery
« Reply #7 on: March 22, 2011, 11:41:50 AM »
... and it may need more than one cycle. If/when you get a green light, disconnect the battery and reconnect again. You'll probably find it goes staright back into desulphate mode.
Keep going. It may take a while.
Mine has resurrected more than one old battery via this route.
MIKE550/4
  • Guest
Re: battery
« Reply #8 on: March 22, 2011, 12:39:24 PM »
ok guys cheers
will put it back on
