Author Topic: crank shells  (Read 1697 times)
Offline steven400/4
crank shells
« on: April 06, 2011, 07:45:38 PM »
does anyone know where the numbers or letters are on the top engine case to tell what colour shells i need i car,nt see them anywhere????? >:( >:( >:(
cb400f2 x7
honda ss 50
gsx 1400
Offline neilma
Re: crank shells
« Reply #1 on: April 06, 2011, 08:48:32 PM »
As far as I can remember, they arent on a 400/4. The only way is to measure the gaps with plastiguage then work out if its within spec. If not, then you get the coloured shells to make up or reduce the gaps.
Offline ttr400
    • CB400F special machined parts
Re: crank shells
« Reply #2 on: April 09, 2011, 03:41:41 PM »
On the 400F there are markings on the rear of the crankcase, however I have never had luck with these codes. I mic the casings and the crank journals and choose the colour of the shells from the book.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
Offline steven400/4
Re: crank shells
« Reply #3 on: April 13, 2011, 06:02:12 PM »
all done now i can find all the letter,s and numbers on the cases crank and conrods
thanks
cb400f2 x7
honda ss 50
gsx 1400
