Author Topic: locked up 550  (Read 1444 times)
Offline mickwinf
locked up 550
« on: October 15, 2011, 10:32:50 PM »
i have just fitted exhaust and carbs to the 550 i am rebuilding but when i tried to turn the engine on the kickstart
 it locked up solid. bummer.it feels like a valve hitting a piston, it will turn backwards and forwards a certain amount but wont go any further.The thing is it was running ok before, and i have not stripped the engine except the outer covers. i have removed the rocker top but it still locks. all the valves seem to be closed and plugs removed so i don't think it is valve timing.Any ideas anyone?
Re: locked up 550
« Reply #1 on: October 15, 2011, 10:47:45 PM »
If all you did was remove the outer covers, then you must have put them back wrong.
Take them off again and turn the engine via a socket on the end of the crank.
Then put bits back on until you find the place where it stops...
2022 Tiger Sport 660
Offline mickwinf
Re: locked up 550
« Reply #2 on: October 16, 2011, 06:20:39 PM »
took your advice Steve, it came loose when i took the alternator cover off but still dont know why, there are no loose bolts or anything to get jammed.Strange!
Re: locked up 550
« Reply #3 on: October 17, 2011, 06:23:17 AM »
If you removed the screws holding th ecoils they can move and jam on the rotor OR one or more of the locating dowels for the cover are missing
Offline mickwinf
Re: locked up 550
« Reply #4 on: October 17, 2011, 08:29:55 PM »
thanks Bryan will check
