Author Topic: Rear Wheel  (Read 1494 times)
Offline H2Eric
Rear Wheel
« on: November 25, 2011, 04:25:24 PM »
I have a K3 frame and swinging arm, I also have a rear wheel which came out of a K7, which of course will not fit as the later swinging arms were wider at the rear. It's not just the spacers that are different as the K7 wheel will not center in the K3 swinging arm. Is it perchance that it's the sprocket carrier that's the issue here?
Some measurements
back of sprocket to flange
Depth of bearing housing to sprocket
If the earlier sprocket carriers are narrower and assuming that the cush drive is the same then providing I can find one perhaps I might be able to use the K7 hub with the K3
Any info gratefully received
Eric
Re: Rear Wheel
« Reply #1 on: November 25, 2011, 06:00:38 PM »
I've no info that can help, but may be taking your caliper out to a bike meet would get you something to mesure if you can't get info here.
Offline Voxonda
Re: Rear Wheel
« Reply #2 on: November 25, 2011, 06:31:55 PM »
Hey H2Eric,
Yes, the sprocket carriers from the K2-K6 are narrower than the K7's. There is a 10 m/m difference, because the double bearing off the axle that carries the front sprocket is also 10 m/m wider.
Left is earlier type, right is K7.
Cheers, Rob
Better sorry for failing than for the lack of trying.
Offline H2Eric
Re: Rear Wheel
« Reply #3 on: November 26, 2011, 04:10:27 PM »
Hi Rob
Many thanks for the info. all I have to do now is find a K2-K6 sprocket carrier.
Eric
Offline Voxonda
Re: Rear Wheel
« Reply #4 on: November 28, 2011, 04:50:56 PM »
If you can't find one let me know, have a nice one here.
Cheers, Rob
