Author Topic: Clutch cover bolts (x 4)  (Read 1197 times)
PikeyBoy
  • Guest
« on: March 11, 2012, 04:10:42 PM »
Have stripped the clutch out on my bike to check the plates, however when reassembling how tight should I do the 4 bolts that go through the springs.
Thanks in advance for any help.
Pikeyboy.
Offline deltarider
Re: Clutch cover bolts (x 4)
« Reply #1 on: March 11, 2012, 06:50:26 PM »
Do NOT tighten them according manual torque. Don't ask me how I know. Just use your senses.
Cf. http://forums.sohc4.net/index.php?topic=72806.msg808595#msg808595
« Last Edit: March 11, 2012, 06:54:11 PM by deltarider »
Offline jcknapp
« Reply #2 on: March 12, 2012, 03:09:28 AM »
I accidently overtightened and the bolt broke so yea not too tight but enough to keep them on solid. maybe use a torque wrench if you have one available.
TON UP!!!
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 12, 2012, 10:22:53 AM »
Don't those bolts bottom out? I just tighten them till they stop. :) Never a problem.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
