Author Topic: Simoniz Engine Enamel  (Read 9927 times)
Offline tom400f
« on: September 14, 2012, 10:00:33 PM »
I've used this on my caliper and the finish is nice. My question is do I need to bake it and if so at what temperature and for how long? If it was on an engine it would get hot of course, so some sort of heating seems sensible .
The can says its cured after 24h and is good for 120C. Anyone know what that means?
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Re: Simoniz Engine Enamel
« Reply #1 on: September 15, 2012, 08:25:40 AM »
120°C is nowhere near enough for an engine paint.
Are you sure it says "engine paint"? - are you sure it says "120 degrees"?
2022 Tiger Sport 660
Offline tom400f
« Reply #2 on: September 15, 2012, 10:15:27 AM »
Hence my request for clarification!
First time I did it I wasn't happy with the result so I removed it with paint stripper. Came off very easily so I don't think without baking its properly hardened.
« Last Edit: September 15, 2012, 10:38:41 AM by tom400f »
1978 CB400F2 Yellow
1995 VFR750FS Red
Offline NE0
« Reply #3 on: September 15, 2012, 10:45:43 AM »
I can confirm I used this Simonez engine enamel for my DT175MX.
I painted it gloss black last year and its doing fine: whilst 2 strokes get hot and i'm sure helped to harden it, The cylinder obviously gets hot but the gearbox doesn't get that hot at all.
I sprayed the whole lot and whilst it may have lost some of its initial sheen . it looks more like factory finish now than it did when i first applied it (Yams were satin)
i didn't want to use the Matt which is rated at 300c on the can.
Nonetheless, mine has turned out just fine, no flaking, I didn't bake it, but i did apply thin coats in FULL sun, not sure when that was as i don't think we've seen the sun much since!!!
I have heard a perfectly acceptable finish can be achieved from using Barbaque paint. BBQ.
In fact over at the yamaha forum its quite rated, although i'd already sprayed mine before i knew it!
I'm currently spraying my 400/4 engine with EHT (extremely high Temperture paint, not VHT)
Not used it before but it seems to cover well.
20yrs ago I used Eastwoods engine paint (no longer availble, I checked with Eastwoods USA)
That was the dogs danglies and looked as if it had only been applied recently not 20 years,In fact it looked good right up to taking it off the road last month for an engine overhaul.
« Last Edit: September 15, 2012, 10:52:42 AM by NE0 »
I hope to die peacefully in my sleep, just like my Uncle..............unlike his terrified passengers!
Offline NE0
« Reply #4 on: September 15, 2012, 11:37:29 AM »
Incidently, 120c is bloody hot! 20 degrees higher than boiling water!
Engines get hot, yes but when it rains, if the engine was well over 100c then rain would boil as it hits the cylinder head and engine, steam would be generated continually.....but it doesn't.
A stationary engine will get hotter yes but the engine is air cooled,...engine paint rated at 120c is fine for an engine but NOT exhausts.
Quote
120 degrees sounds like IT shouldn't be ok, but manufacturers do a lot of research and if it wasn't any good for engines they wouldn't sell it.
Offline tom400f
« Reply #5 on: September 15, 2012, 09:30:14 PM »
Yes - thin coats are the key or it sags. I did mine in the sun too - last weekend was nice at least. Put another couple of coats on today.
Thanks for the advice - no baking it is then.
1978 CB400F2 Yellow
1995 VFR750FS Red
« Reply #6 on: September 15, 2012, 09:46:12 PM »
A bit of internet research indicates that air-cooled engine cylinder heads run at between 130 and 145 degrees C
Exhausts can reach 400 degrees C at the cylinder head, falling to 250 degrees C at the outlet.
Offline UKROBK7
« Reply #7 on: September 19, 2012, 07:27:17 PM »
Some of these engine paints are meant for watercooled engines and not air cooled ones
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: September 19, 2012, 09:46:12 PM »
I would say it's made for car engine blocks which don't get near as hot as air cooled CB's.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline Seamus
« Reply #9 on: September 19, 2012, 10:05:32 PM »
Interesting stuff. I have used Simonize for a while and it has been fine (on 2 engines). Looking at a can, the 120C relates to gloss black only. Matt black and aluminium are rated to 300C, but do have a cure clause saying that they should be heated to 220C for 90 minutes to achieve full cure.
Offline NE0
« Reply #10 on: September 19, 2012, 11:17:18 PM »
Quote
It does state on the can........... for cars and Motorcycle engines
Like I said it's fine on my DT175MX, aircooled two stroke...........
