Author Topic: CB175, Electronic Ignition???  (Read 3909 times)
Offline Isleofmanfan
« on: November 01, 2013, 07:12:42 AM »
Hello,
        does anyone know if there is an Electronic Ignition kit available for a road going CB175?
Regards,
Mike
"Don`t wait for your ship to come in. Swim out and meet the bloody thing!"
Barry Sheene.
Online Bryanj
Re: CB175, Electronic Ignition???
« Reply #1 on: November 01, 2013, 08:49:34 AM »
Doesn't the CB have two sets of points? Don't think there is an electronic kit but Hondaman on the US site does a kit for the fours that reduces the voltage and current at the points so they don't spark and wear out so the spark stays better for a long time. If I am right about the twin contacts it should work on the 175
« Reply #2 on: November 01, 2013, 06:30:08 PM »
Thanks Bryanj...I can only see one set of points!
Is that where i`m going wrong?
 :o
Barry Sheene.
« Reply #3 on: November 01, 2013, 06:46:49 PM »
CB175 had 360° crank (both pistons go up and down together) so used wasted spark - just like the fours.
That's why they sound so good compared to the CB250/350/360 which had 180° crank and uneven firing sequence.
2022 Tiger Sport 660
Online Bryanj
« Reply #4 on: November 01, 2013, 09:40:55 PM »
You are probably correct Steve, it's been a long time since i worked on one
« Reply #5 on: November 02, 2013, 09:41:49 AM »
You can use a Sparkrite TT electronic ignition on the CB175, it retains the points, but using a much lower voltage across them, resulting in much longer life for the points and less frequent adjustment. Found just what you need on e-bay, item number  151154496435   he's got 2 of them, apparently new and unused, probably worth a punt if you want to go down that route ;D
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: November 02, 2013, 09:26:50 PM »
Is the Hondaman box the same idea as the Sparkrite?
« Reply #7 on: November 16, 2013, 05:52:59 PM »
Cheers....
Got both of them for £10.50  ;D Fitted one today and there is a vast improvement.
Should I do away with the condensor all together?
Barry Sheene.
