Author Topic: New member Derby  (Read 2593 times)
Offline MarkCR750
New member Derby
« on: January 31, 2014, 06:39:17 PM »
Hello, I'm building a CR750 replica (well look alike at least) so joining the forum seemed a good idea, apologies to any purists but the K7 that I am using as a base had sat in a garage with a leaking roof since 1995 and was beyond economical restoration, look forward to speaking to you, cheers Mark.
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Re: New member Derby
« Reply #1 on: January 31, 2014, 06:53:28 PM »
Welcome Mark, it would of been cheaper to fix a leaking roof than to restore a 750K. Enjoy.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: January 31, 2014, 07:12:54 PM »
Welcome Mark.
I've never seen a CB with a roof never mind a leaking one.   :P
« Reply #3 on: January 31, 2014, 07:15:37 PM »
Welcome mark - look forward to hearing about your project. I've been assembling parts to do the same for a while now - so will watch with interest. James.
Offline MarkCR750
« Reply #4 on: January 31, 2014, 07:19:01 PM »
Welcome Mark.
I knew I was risking that response when I wrote it!  :)
Sir J.Stewart.
Offline MarkCR750
« Reply #5 on: January 31, 2014, 07:26:58 PM »
Hi James, I'll post some photos in the next few weeks when it starts going back together, so far frame modded/powdercoated, engine back in, no major work done, I'm putting it on the road so it's basically a stock K7 engine, (I have another engine that I will eventually fit once I've put the big bore kit on it, removed the generator, done cam etc etc), I am currently doing the twin disc conversion and fitting rear sets, my target is end of May so that I can take it to the TT.
Sir J.Stewart.
« Reply #6 on: January 31, 2014, 07:27:46 PM »
Awesome, can't wait to see it..
Offline MarkCR750
« Reply #7 on: January 31, 2014, 07:33:07 PM »
When I first got the bike home I did briefly think of restoring it, when I saw the cost of an exhaust system I soon changed my mind!, actually would have been cheaper to build an entire garage  :o
Sir J.Stewart.
Offline bytio
« Reply #8 on: January 31, 2014, 09:44:49 PM »
Good luck Mark, I think I met you in A bike shop when I was getting a tyre fitted?
Offline MarkCR750
« Reply #9 on: January 31, 2014, 10:07:19 PM »
That's right, racing lines, I also remember seeing your mint Honda Britain on the way to Matlock, I trust it's safely tucked up for the winter?
Sir J.Stewart.
Offline mick
« Reply #10 on: February 01, 2014, 08:07:51 AM »
Hello Mark and welcome to the forum  ;), post some photos of your progress when you get chance  ;) cheers Mick
Offline UK Pete
« Reply #11 on: February 01, 2014, 11:02:11 AM »
Hi Mark welcome to the forum, lots of 750 owners on here so if you get stuck with anything there will be helpful advise to hand
pete
Offline MarkCR750
« Reply #12 on: February 01, 2014, 04:45:21 PM »
Thanks Mick, will do in a few weeks , not much to see at present, engine in, oil tank in (used the original oil tank mounted transversely, looks quite convincing as a period part but I will fit a CR replica when funds allow), I have the fuel tank and seat unit but not fitted yet cheers Mark.
Sir J.Stewart.
Offline MarkCR750
« Reply #13 on: February 01, 2014, 05:07:13 PM »
pete
Cheers Pete, just got stuck for the first time actually!, I plumbed in the oil tank, re-fitted carbs and exhaust, slaved a battery and original fuel tank today and went for a start......but it didn't !, getting a spark but the plugs don't seem to be getting wet so I suspect it's a fuelling issue, last time I started the engine was 5 months ago and I didn't re-clean the carb internals before re-fitting the carbs today  ::), now run out of time/daylight/skill so it will have to be tomorrow now.
« Last Edit: February 01, 2014, 05:08:52 PM by MarkCR750 »
Sir J.Stewart.
Offline MarkCR750
« Reply #14 on: February 02, 2014, 10:05:38 AM »
Up and running now, I hadn't appreciated how much it needed the airbox fitted to start!, I will be re-jetting for velocity stacks soon so if anyone needs a K7 airbox let me know. Off out on XJR now to celebrate  ;D
Sir J.Stewart.
