Author Topic: oil level  (Read 1908 times)
CATTY F1
  • Guest
oil level
« on: July 24, 2006, 11:51:31 AM »
Hi All.
Having just bought my first CB750 F1 supersport and being new to this forum i was wondering if someone could shed some light on a problem im having.
I checked my oil level and it wasn't registering on the dipstick, so i topped it up (as the manual says) to half way, took it for a ride and it just sput it out of the breather tube all over the bike. Why?  Before i put it in the bike was running fine but i could not tell how much was in there which is why i decided to top it up just in case.
Cheers.
Dave.
Offline JonnyB
  • Repeat: It's only a Hobby, It's only a Hobby....
    • BatchScan
Re:oil level
« Reply #1 on: July 24, 2006, 12:35:19 PM »
I think this happens when oil is seeping into the crank case from the oil tank, I've never seen it but I have heard of it,
Oil is not meant to flow out of the tank, so you may have a stuck pressure release valve or the pump may just be worn out
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case -  K100/1200 hybrid
John
https://batchscan.co.uk/
jimshea
  • Guest
Re:oil level
« Reply #2 on: July 27, 2006, 11:04:10 AM »
John's point is correct re the stuck release valve.. have you tired draining all of the oil out and checking how much you get out?? Did you do an oil change?
