Author Topic: it works!  (Read 3560 times)
Offline florence
it works!
« on: April 14, 2014, 03:10:15 PM »
15 months under a tarp in the garden; oil change plus filter, fresh fuel, drained carbs, charged battery, started third kick, it even ticks over by itself.  Must be a Honda.
New chain and sprocket set, headlamp, rear tyre and brake shoes.  I just need to put some filler in the front mudguard, a new hole has appeared but the rest is still solid.  Scrub that, gaffa tape will do for now.
I just need to bleed the front brake, rub over with an oily cloth and should be ready for MOT.
Offline florence
Re: it works!
« Reply #1 on: April 14, 2014, 03:12:42 PM »
Offline mickwinf
Re: it works!
« Reply #2 on: April 14, 2014, 07:59:59 PM »
Glad its going back on the road, are you sure the wipe with the oily cloth is really  necessary? don't want to shock it too much!!
Re: it works!
« Reply #3 on: April 14, 2014, 08:01:35 PM »
Tip:
Don't wipe the seat...
... or the discs  ;)
2022 Tiger Sport 660
Offline Green1
Re: it works!
« Reply #4 on: April 14, 2014, 08:35:48 PM »
Tip:
... or the discs  ;)
My brother did that years ago to my dads Triumph Trophy  ::) it sent the cover rock hard.
I used it the other day and it's still as slippery as hell I nearly slid of the side so I roughed it up with sandpaper. :)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline LesterPiglet
  • 1977 CB550F2
Re: it works!
« Reply #5 on: April 14, 2014, 08:59:30 PM »
I'll never forget doing my seat with Mr. Sheen.  ::)
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline florence
Re: it works!
« Reply #6 on: April 14, 2014, 10:19:51 PM »
it does need oil in some parts, paint falling off, angry rust appearing, but great to have it going again.  Brakes working now which is a bonus.  I think I'll record the sound of it running and share the file, I had forgotten how fab it sounds with that Laser pipe.
Plan to put the bike in my next 'pop video'. ;D
Offline Paull
Re: it works!
« Reply #7 on: April 14, 2014, 10:29:11 PM »
Hi Florence,
I Like em used.
Well done.
Duck oiled a seat once had a girl on the back one minute, gone the next.
That was the end of that relationship.
Paul
S**t Happens
Offline florence
Re: it works!
« Reply #8 on: April 15, 2014, 08:28:36 AM »
yes, I would agree with that.  I took it for a test ride and the front brake is dragging slightly.  A bit annoying because MOT chap won't like it.  I should have checked all this before I bled the brakes but I was too excited about being so near to riding it.  Looks like I'll have to redo.  What I don't know is whether it will just free itself up with use?  It's twenty miles to the MOT place......
Offline matthewmosse
Re: it works!
« Reply #9 on: April 15, 2014, 08:38:08 AM »
Better to clean up and fix now then have to make 2 trips to mot place. WD40 and a bit of freeing off for 20 minutes will genrally get it ok for a short time, but a full strip and clean then re assemble with grease in pivots will give a better result I would think.
Offline florence
Re: it works!
« Reply #10 on: April 15, 2014, 03:23:38 PM »
thanks, wise advice.
Offline florence
Re: it works!
« Reply #11 on: April 15, 2014, 05:43:41 PM »
took off the offending part and it looked like it had been at the bottom of the ocean for several decades, now soaking in plus gas.
Offline florence
Re: it works!
« Reply #12 on: April 15, 2014, 08:40:44 PM »
thanks, all freed up now and greased.  I will put back together tomorrow and all should be good.  MOT Saturday.
Offline florence
Re: it works!
« Reply #13 on: April 19, 2014, 12:47:26 PM »
MOT passed, no advisories.
Offline Green1
Re: it works!
« Reply #14 on: April 19, 2014, 01:56:42 PM »
Good to see she passed.
MOT's always worry the hell out of me even when I know it will pass.
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
