Author Topic: New in  (Read 10752 times)
Re: New in
« Reply #15 on: September 09, 2014, 07:30:30 AM »
When doing a PDI you barely had time to scratch your arse never mind outthink mr Honda mate!!
Offline tom400f
Re: New in
« Reply #16 on: September 09, 2014, 10:11:08 AM »
Ah OK - the original manual must be right. That said, I got my bike when it had only 1800 miles on it. I suspect it was like that from the factory. May be I should move it  ::)
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline Clem2112
  • Midlife
Re: New in
« Reply #17 on: September 09, 2014, 12:29:11 PM »
I can see the sense for the cable guide ring being secured  horizontally if the cable is re-routed  over the coils to give a bigger arc.
Mr Honda liked to put all the cables through that front chromed clip which seems to confirm the position of the rear guide on the engine breather cover - the guide's rubber sleeve and clearance from the engine ensures cable survival I would think.  The coils get a tougher time !
bike-pusher
  • Guest
Re: New in
« Reply #18 on: September 09, 2014, 02:06:04 PM »
I've only ever seen that cable loop attached to the top of the cam cover, at least on bikes that I know have never been molested.
Offline Woodside
Re: New in
« Reply #19 on: September 09, 2014, 06:46:15 PM »
Just got in from work and after reading this discussion. Apart from thinking I should have called this thread "where does the clutch cable bracket go".. I had a good look at mine and then had a really good look at the diagram again and have blown it right up.....
First off it looks pretty at home on the coil bracket.
But more interestingly after blowing the diagram up to doesnt really apearr to be fixed to anything...so perhaps this is where the confusion is ...that it was completely open to interpretation ???
Offline Woodside
Re: New in
« Reply #20 on: September 09, 2014, 07:17:30 PM »
Hi trigg
Did you get the pm
As the site does not seem to save sent Pm's in sent message folder (Steve is this correct)
Online SteveD CB500K0
Re: New in
« Reply #21 on: September 09, 2014, 08:15:51 PM »
Two things about PMs:
1. The forum default is not to save sent messages in the "Sent Messages" folder. You have to set this in your forum profile under Personal Messaging (don't worry - I just set yours for you...)
2. If you reply to the email notification (you know, the email that says "Do not reply to this email"), it won't go anywhere. I got sick of receiving them and decided to let the server dump them.
Now, the "Save a copy in my outbox" checkbox should be ticked by default and you have a record of everything you've sent.
I have never known the forum "not send" a PM - if you think they are not getting through, check the above.
Steve
2022 Tiger Sport 660
Offline Woodside
Re: New in
« Reply #22 on: September 09, 2014, 08:19:59 PM »
Thanks Steve your a star
Re: New in
« Reply #23 on: September 09, 2014, 08:32:48 PM »
Yep, i got your PM ;) And i did send one back.
« Last Edit: September 09, 2014, 08:36:06 PM by trigger6969 »
Re: New in
« Reply #24 on: September 09, 2014, 08:50:37 PM »
Now he bloody tells us !
Re: New in
« Reply #25 on: September 09, 2014, 09:02:01 PM »
Sorry Steve. Just got off a flight from the IOM.
Offline Woodside
Re: New in
« Reply #26 on: September 09, 2014, 09:09:19 PM »
Like I say it looks quite t home on the coils
Sorry about the real close up but I had to reduce it so much to get past the what's it's name that counts the pixels / mega bites do dah
« Last Edit: September 09, 2014, 09:12:09 PM by Woodside »
Re: New in
« Reply #27 on: September 09, 2014, 09:17:41 PM »
I've upped the limit from 400k to 1Mb (per attachment)
4Mb total per post
If you can't fit your picture in 1Mb then we don't want to see it!  (much)
Offline Clem2112
  • Midlife
Re: New in
« Reply #28 on: September 09, 2014, 09:45:54 PM »
The workshop illustration shows the cable guide being quite distant from the rearward coil bolt. Must be attached to a cover bolt?
Re: New in
« Reply #29 on: September 09, 2014, 09:50:48 PM »
PLEASE: Someone put a end to this ;D
