Author Topic: MPG on a CB750F1  (Read 3327 times)
MPG on a CB750F1
« on: September 23, 2014, 09:04:00 AM »
Just spent the day cruising around North Wales, did about 146 miles of mainly A and B class roads, generally keeping to the speed limits (mainly 60 mph), the bike ended up doing 48 mpg, is this a normal figure for these bikes, in the olden days I just filled the thing up with no thought to fuel economy so I have no idea of what it used to do.
bike-pusher
Re: MPG on a CB750F1
« Reply #1 on: September 23, 2014, 10:36:46 AM »
It depends on the gearing.
Honda geared the F down for better acceleration, and the one I ran in the very early 1980s was a tad thirsty, like around 40-42mpg.
If you fitted a gearbox sprocket off a K6, it made a hell of a difference: more relaxed cruising and consumption of 45+mpg, depending on throttle hand.  I also acquired a five-gallon alloy tank for long journeys (like down to the Bol), because the fuel range on the standard tank was poor.
So 48mpg sounds realistic if it's been geared up.
I really disliked that bike, and only kept it for a year......  I twinned the front discs, fitted Girling rear shocks, decent tyres, and in the end sold it and went through a Moto Guzzi phase....
« Reply #2 on: September 23, 2014, 12:23:03 PM »
The bike is bog standard, just as I bought it in 1976, I must confess that it is not my favourite CB750, that title must go to my 1970 CB750, or my 1971 CB750K1 with a 900cc conversion, but it's the one that I have got and I've had it that long that I will be keeping it.
Den
Offline gamma
« Reply #3 on: September 23, 2014, 12:35:09 PM »
Well if you ever decide to sell, I'm looking for an F1.  My project bike has no registration, so I need one to use as the base, for registration in Spain  :)
bike-pusher
« Reply #4 on: September 23, 2014, 12:41:05 PM »
Well I suppose you could get 48mpg out of one on stock gearing.  I never had the self-restraint!
And if I'd had a bike that long I wouldn't sell it either....
I remmeber taking mine to the Bol in 1982, with a mate on the pillion.  That silly knicker-elastic chain had worn slack at some point in the run down there, to the extent that it was rattling on the chainguard, and when we stopped for petrol I decided I'd adjust it.  And lube it.  As I spun the back wheel, I saw the spring clip had popped off, and the sideplate had fallen off as well.  Eek.  Amazingly, I had a spare spring link with me.
Other memories were how it didn't stop in the rain, until somebody invented sintered brake pads....  Nice engine, though.
Got an F2 now - they should have built the F1 like the F2 right from the start.
« Reply #5 on: September 23, 2014, 01:20:12 PM »
Yes I remember the standard chains in them days, some bright spark amongst us decided that it would be a great idea to go down to Brands Hatch to watch the racing for the day (from the Wirral), I was on my K1 and on the way there we stopped for petrol and the chain looked all rusty and was kinked. I had to buy some oil and soak the chain with a rag. When we got back I bought a Reynolds 3/4" chain conversion which solved that one, I swapped the sprockets and chain to the F1 when I bought it but had to swop back when I couldn't get the chain anymore.
At the moment I am re starting my F2 project, so I will see how that one gets on.
Den
« Last Edit: September 23, 2014, 01:21:54 PM by Spitfire »
Offline gamma
« Reply #6 on: September 23, 2014, 06:14:47 PM »
I was unlucky to have the chain break on my F1 in 1978.  I had fitted an Izumi, I think it was called, and it was supposed to be self lube!  It broke on the A47 not long after I had fitted it, it did the usual thing and wrapped itself around the front sprocket punching into the upper and lower crankcases.  I used doublebond and araldite to repair the damage, after draining the sump.  I fitted an o-ring endless chain after that.  The bike was stolen in 1980 along with the marzochi shocks, Tomasselli clip-ons and Raask rear sets.  I bought an F2 after that.  But I also just filled these bikes up with no idea what miles per gallon I was getting, other than the tank range was not good on trips to the continent.
« Reply #7 on: September 23, 2014, 06:19:17 PM »
I never went anywhere on my 500 without a spare chain link. I still have it!
Mid-40's on the 500/4 if I remember correctly.
2022 Tiger Sport 660
Offline Green1
« Reply #8 on: September 23, 2014, 07:57:42 PM »
Maybe my bikes due a service I only get around 35mpg  :o
Its returning less than my ranger
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #9 on: September 23, 2014, 11:56:08 PM »
 must remember to get a spare link,get around 10 miles per litre,so about 45 Mpg,thats cruising around 5k-6k all the time,on my
M plate 500-4
Offline matthewmosse
« Reply #10 on: September 24, 2014, 08:34:09 AM »
About 70mpg in perfect conditions from my 550 k3 was the best I ever saw on a sohc honda. No traffic, no towns. The 500/4 N reg could chew through a tankfull in 100miles or make it last 140+. The 500/4 had a sidecar so one has to expect any hill to cause a rapid drop in mpg. Both did really well if a motorway was involved, at various times the 500/4 may have had a smaller rear sprockett.
bike-pusher
« Reply #11 on: September 24, 2014, 09:22:50 AM »
My CB550F2 was ludicrously thirsty.  About 40mpg, and on one memorable thrash in France (trying to get to the hotel before the restaurant closed, after a delayed ferry crossing), it ran onto reserve at 76 miles.....
My 550 FourK was much better.
The 400 Four returns high 40s - low fifties if used gently, and low 40s if thrashed.  Haven't actually run a tankful through my 750F2 yet, so dunno about that.
Offline MarkCR750
« Reply #12 on: September 24, 2014, 01:08:09 PM »
Steer clear of xjr1300's chaps!šŸ˜ƒ
Suzuki GT250A (Nostalgia)
1977 K7 CR750 (lookalike, what of Iā€™m not sure)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Offline Waggles
« Reply #13 on: October 02, 2014, 10:47:31 AM »
OK, before giving you my figures I must fully confess to being a 'Careful' rider, my wife calls me 'Field Marshall Slow' on the basis that James May would no doubt pass me with ease! I only 'Open her up' occasionally to, er, 'Burn the carbon off the valve seats officer'.
My bike is in totally standard trim in every way except the inevitable MOTAD exhaust and unbelievably I get 48 mpg around town and on a gentle 50 mph cruise up the A1 I got 57 mpg! The gearing is believed to be standard F1 as I bought new sprockets with the chain in a set for the F1 and the revs seem similar to what I remember back in the day ( around 4600 rpm at 70mph )
I think 48 mpg for a more normal individual would be a very good average
bike-pusher
« Reply #14 on: October 02, 2014, 11:45:11 AM »
Blimey.  Never, ever rode mine at a steady 50.....
