Author Topic: Starting the engine  (Read 31986 times)
Offline El__burro
Re: Starting the engine
« Reply #105 on: January 23, 2015, 04:09:22 PM »
After 2 hours research i went on to buy Seal All, its an adhesive/sealant resistant to oil and fuel, it's recommended for use on carbs floats.
Hopefully that'll do.
Also, where is the best place to shop for carbs needles and spares?
El__burro
Offline mike the bike
« Reply #106 on: January 23, 2015, 05:13:09 PM »
I can see you're in the sh1t so you can have one I've got spare in the shed.  PM me your details and I'll send it.
« Reply #107 on: January 23, 2015, 06:50:25 PM »
Even though its not for me Mike you are a sohc gentleman
Bitsa
« Reply #108 on: January 23, 2015, 07:52:23 PM »
 lovely gesture Mike,
« Reply #109 on: January 23, 2015, 07:55:29 PM »
Agreed
Bitsa :D :D
« Reply #110 on: January 23, 2015, 09:17:45 PM »
Sorry to raise your hopes but after seeing the photo you just sent me, I realised we were talking about different bikes.  My cards are for a 400.
I've got a right load of omelette on my face now.
Once again, so sorry.
Offline El__burro
« Reply #111 on: January 23, 2015, 10:01:53 PM »
Don't worry,  I'll wait for the glue, if that doesn't work I'll invest in a carb #4.
Still many thanks for trying.
El__burro
« Last Edit: January 24, 2015, 09:52:59 AM by El__burro »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #112 on: January 23, 2015, 10:44:17 PM »
That carb damage is repairable. There is a guy on our sister site who does it. There may be someone who can do it closer to home.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #113 on: January 24, 2015, 01:56:22 AM »
Don't think you'll get good results with 'Seal All' as it's fundamentally a sealant type of contact adhesive, whereas you're trying to bond a very granular / small surface area 'post'.
Honestly I reckon you'd do far better with John's JB Weld suggestion... it IS fuel resistant and will bulk the material around the 'post' giving you the necessary strength. (& is very well used / respected within the automotive community)
Regarding JB Weld, in the Q & As below appreciate that it should be applied to dry / clean surfaces .... but when cured is fully resistant to fuel. Ie to not apply it to a wet surface.
If you do use Seal All, and it does a great job do let us know... always keen to learn & equally happy to eat my words.
Simon
« Last Edit: January 24, 2015, 02:08:48 AM by Lobo »
Offline El__burro
« Reply #114 on: January 24, 2015, 09:51:56 AM »
Lobo, on Bitsa suggestion I went to ask the US forum,  the answer is no,  JB weld will not sort the problem.
There's this guy Jim F, he seems to be doing a good job at microwelding it but I reckon the cost will be higher than buying a full set of carbs.
I'll let you know if seal all is any good.
El__burro
« Reply #115 on: January 24, 2015, 09:57:50 AM »
El__burro
You should be able to pick up a single carb body from the states for about $20.
« Reply #116 on: January 24, 2015, 10:33:02 AM »
Ask Trig which carb body I sent him and if it's NOT that one you need I still have the other three somewhere. You can have it for the cost of posting if it's any good.
Ash
« Reply #117 on: January 24, 2015, 11:02:11 AM »
Ash
I can't remember now Ash. It was before my brain transplant  ;D
Offline El__burro
« Reply #118 on: January 24, 2015, 11:04:47 AM »
Ash, I will send you a picture of the one i am after. Hopefully you'll see if it matches any of the 3 you have.
Thanks in advance.
El__burro
