Author Topic: Braided brake lines  (Read 1781 times)
Braided brake lines
« on: November 26, 2014, 09:29:34 PM »
I bought a set of braided hoses for the front brake but the bottom hose is much longer than the standard one.
It's long enough to go all the way to the caliper without using the metal brake line. Is that ok as long as it's secured away from the wheel?
If it is, I've got a brand new repro metal brake line going spare!
Offline matthewmosse
Re: Braided brake lines
« Reply #1 on: November 26, 2014, 09:55:36 PM »
On all my sohc hondas the braided lines completely replace the whole brake line, caliper to master, some still use the junction on the yokes, others move the front brake switch to a banjo in placevof the pressure switch on the yoke. My bikes are cb550 and 500 so may be a bit different.
« Reply #2 on: November 26, 2014, 10:00:35 PM »
Great. That helps a lot. Cheers.  :)
Offline tom400f
« Reply #3 on: November 26, 2014, 10:51:04 PM »
I got a set of Earls lines via Inox Fasteners. They still use the junction so the pressure switch is not disturbed.
It was an option to keep the rigid pipe or get lower hose that went straight to the caliper but that looks ugly to me so I retained the rigid pipe.
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline Norniron
« Reply #4 on: November 26, 2014, 11:02:26 PM »
Wots ugly about this?
1977 400 cafe
1972 500/4
2013 triumph STR675
