I have the same switch as this on a CB500K0 UK model. Have seen them fitted to CB750K2's. Is it a single cable switch. On the 750 K0 your switch should have a black kill switch and look like this >> http://www.yamiya750.com/index.php?main_page=product_info&cPath=144_70&products_id=1925
Thanks guys, that throws a lot more light on the subject! Yes, it's single cable. The parking light staying on is also non standard I believe? With the correct switch it should extinguish.. Either way, it 'ain't right. If you look closely, it's been hand painted. I'm reluctant to take it off, re thread the wiring loom through the handlebar and risk upsetting all four positions of the slides with the new switch, which isn't cheap. I'm going to remove the red paint off the kill switch delicately and asses the end the result. What were they thinking!!😳 thanks. Nige. Ps, it's the pull only cable on this K0 750rideruk, but it may well have the 2 locators within? I'll let you know.
Morning Trigger, Sorry, were you referring to the throttle cable? I was. There are 2 outlets, one is the 'pull' cable and the other hole is blocked with a screw/spring arrangement that would have allowed the K1/2/3 system to operate - a much better system of course. This screw reminds me of the cruise control system that locks the throttle in place on some bikes whilst crusin' the Highways in the States etc. do you want a photo? Nigel.
