Author Topic: Why has a cg125 got me stumped  (Read 3763 times)
Offline Green1
« on: February 08, 2015, 08:07:28 PM »
I'v been messing around with another cg125 the last couple of days but this one has me stumped.
Its had a full service carb cleaned and valves adjusted it starts dead easy when cold with a perfect spark but when warm it backfires coughs and farts before stalling.
when it does run it struggles under load when its cold it will do 30ishmph but as soon as its warm it gradually grinds to a halt.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Why has a cg125 got me stumped
« Reply #1 on: February 08, 2015, 08:12:34 PM »
Mick
Am I right in recalling the points and condensor is in the flywheel?If you are happy with the carb setup when she warms up this stuff starts to break down.Really cant remember so jog my memory and maybe I can help you out.I personally liked the CGs.
Ralph
Offline Green1
« Reply #2 on: February 08, 2015, 08:32:39 PM »
Sorry Ralph forgot to mention its a 1996 cdi bike
Didn't the early ones have the points in the head
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #3 on: February 08, 2015, 08:38:33 PM »
Mick
Thats way past the time I last worked on them.As i said though if you are 100 percent with the carburation the electronics tend to break down when hot.Never took to cdi units and cant remember where the friggin points are thought still in the flywheel Bryan will confirm that.
Ralph
Offline Green1
« Reply #4 on: February 08, 2015, 08:46:54 PM »
That's what I thought good job cg bits are cheap ordered a new coil and another cdi unit and fixed a couple of dodgy crimps so fingers crossed.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #5 on: February 08, 2015, 08:48:36 PM »
Excellant wish the best
Ralph
Offline Green1
« Reply #6 on: February 08, 2015, 08:57:14 PM »
I was going to shove it in the truck tomorrow to avoid  paying £25 a day parking but never mind.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #7 on: February 09, 2015, 01:52:50 AM »
I had a c50 doing similar years ago, check the compression as the restricted engines can burn the valves just enough to cause problems
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: February 09, 2015, 12:36:03 PM »
Does this CG have automatic choke?
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline Green1
« Reply #9 on: February 09, 2015, 05:33:28 PM »
There's no auto choke it just got a little lever on the side of the carb.
I haven't checked the compression yet but it just kicked back bloody hard so it can't be to bad.
There was a small air leak around the head of new exhaust fitting it properly seemed to improve tick over slightly.
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Green1
« Reply #10 on: February 10, 2015, 05:41:52 PM »
Changed the plug cap and its still the same it has a brilliant blue spark.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #11 on: February 10, 2015, 06:53:21 PM »
Mick
Still think electrical coil ok?
Ralph
Offline Green1
« Reply #12 on: February 10, 2015, 07:01:31 PM »
Not tested the coil I'm just going to swap it when the new one arrives
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Green1
« Reply #13 on: February 11, 2015, 02:34:42 PM »
The new coil arrived so I fitted that wish I didn't as it made it a lot worse there were only about 4 strands of copper in the new lead.
Just as I was about to give up the new CDI arrived plugged that in and it fired up instantly  :) took it for a run and its perfect no need to mess with the carb or anything.
The only thing it needs now is a speedo as it just goes around&around&around&around around&around&around&around
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline UK Pete
« Reply #14 on: February 11, 2015, 02:46:58 PM »
Nice one mick, i know what your saying about some of the coils out there
pete
