Author Topic: 1973 k2 Honda 500 carb problems (Sorted now, was coil wiring issue, not carbs)  (Read 10825 times)
Re: 1973 k2 Honda 500 carb problems
« Reply #15 on: April 26, 2015, 05:22:38 PM »
is this kit any good,
 needle,jets ,"O" rings,etc,
 all for under £20 + p&p + VAT
 http://www.davidsilverspares.co.uk/CB500K1-FOUR-1972/part_61450/
« Reply #16 on: April 26, 2015, 06:25:56 PM »
That works out, all for under £100 John. These are cheaper >> http://www.ebay.co.uk/itm/161492636759?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: April 26, 2015, 08:51:32 PM by Trigger »
« Reply #17 on: April 26, 2015, 09:34:16 PM »
thanks Trigger,at present mine are behaving (fingers crossed) but will try to remember for the future,I wonder if the Thread starter ; Jon Stead,will find it interesting?
« Reply #18 on: April 26, 2015, 09:51:23 PM »
He said that he had the carbs done John but, i am wondering if they just cleaned the internals ?
Offline jon stead
« Reply #19 on: April 27, 2015, 10:39:44 AM »
^^ Hi lads, yes saw your posts about spares kits. When teh carbs were rebuilt it was all new David Silver parts inside. The carbs are going back to the overhauler when I get home for him to have another look at now that there are some known faults and feedback. Hopefully he can make them work.
« Reply #20 on: April 27, 2015, 10:18:02 PM »
recently I have noticed the carb setting are more critical,
years ago,it would run with the airscrews open 2 turns,
now ,it is only 1 turn,and 1/8 either way makes a difference,also,what is the state of the air filter ??
Online JamesH
« Reply #21 on: April 28, 2015, 11:22:28 AM »
Also worth checking for any burrs / unrefined castings on the float pin struts - just a bit of fine wet / dry to clean them up can often make the difference.
Offline jon stead
« Reply #22 on: April 28, 2015, 07:07:02 PM »
Thanks for all the tips, much appreciated
« Reply #23 on: May 06, 2015, 06:19:57 PM »
fitted a whole new carb kit and still have the same problem as Jon Stead. Rev's drop after a while but, as soon as you rev up it will not drop lower than 3,000 rpm. Another head scratcher and not sure which way to go.
« Reply #24 on: May 06, 2015, 07:27:41 PM »
Try removing the cables Graham and blipping the throttle by using your hand on the butterfly. If it doesn't do it, then the problems the way the cables are routed or the way they are connected, sometimes easy not to leave enough slack in the cable or the cables sticking.
Cheers Oddjob. Already gone down that route  ;) Even put a electronic Vacuum mate on the carbs so, the balance is perfect.
« Reply #25 on: May 06, 2015, 09:03:11 PM »
You checked the throttle stop screw on the butterfly? it's an eccentric cam arrangement and if it's out it will hold the throttle open even with no cables attached.
Will go through it again tomorrow. I can get it to tick over at 800 rpm but, twist the throttle to 7,000 rpm and it will only return to 3,000 rpm and after a while will return to 800 rpm or drop off completely.
Offline deltarider
« Reply #26 on: May 07, 2015, 07:22:47 AM »
Possible air leaks between carbs and head? O-rings between head and intake manifold are always suspect.
« Last Edit: May 07, 2015, 07:27:38 AM by deltarider »
Offline jon stead
« Reply #27 on: May 10, 2015, 02:49:25 PM »
^^^thanks Delt Rider.
Got the bike running today but it will not tick over. Rides ok ish, apart from a horrendous front wheel wobble and once warmed up is a pig to restart.
When I get more time I will check for air leaks as suggested. At the moment I'm just glad I actually got a rude out if it. Gears work, brakes work, no engine oil leaks, so just this wheel wobble and tick over and jobs a good'un.
Thanks everybody for your support and suggestions, much appreciated.
Offline mike the bike
« Reply #28 on: May 10, 2015, 02:51:19 PM »
Have you checked the idle jets/emulsion tubes?
Offline matthewmosse
« Reply #29 on: May 10, 2015, 04:52:40 PM »
Outside chance here, but the bit about being a pig to restart once hot reminded me of my first cb550, it had most of the same symptoms as I recall, it was down on compression thanks to the rings being mia on top of pistons.... If you don't know the history of the inside of the engine, it might be worth just checking compression. Mine still pulled a ton with the engine like that, pretty well inpossible to start once hot, tickover a pain to get anywhere near right. Valve clearences were often needing adjustment too. Worth a quick check in my books.
