Author Topic: Regulator/Rectifier  (Read 5587 times)
Offline Spanner1972
  • Novice bike builder.
Regulator/Rectifier
« on: May 15, 2015, 01:26:49 PM »
Is there a modern day alternative to the big and bulky system for the CB 550 four? You'll have to excuse my novice question this is all new to me. Thanks.
Re: Regulator/Rectifier
« Reply #1 on: May 15, 2015, 01:56:44 PM »
There are one piece electronic reg/rec units available but the slightest hint of wrong wiring and they are, as my uncle would have said, crodged (or knackered as they say now)
Offline Spanner1972
« Reply #2 on: May 15, 2015, 02:02:02 PM »
Is it best to try and get an old/new/used one or get the newer type and get it professionally wired up? Thanks for the info.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: May 15, 2015, 04:47:21 PM »
Hi Spanner,
DSS (David Silver Spares) sell an all-in-one Regulator/Rectifier unit, which should just bolt on directly to you bike... via one loom plug. I had one on my CB750K2 & it worked a treat. You will be able to remove the regulator unit... just tape up the 3 wires (black, white, green)  & stow them safely out of harms way.
Job done.
Simon
« Last Edit: May 15, 2015, 04:58:19 PM by Lobo »
« Reply #4 on: May 15, 2015, 05:55:20 PM »
Lobo, did you find the acid leaked out of that battery?
« Reply #5 on: May 15, 2015, 06:19:00 PM »
When I click on it, the picture opens the correct way up!
2022 Tiger Sport 660
Offline mike the bike
« Reply #6 on: May 15, 2015, 06:22:56 PM »
What's with the 13A fuse?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #7 on: May 15, 2015, 06:46:21 PM »
I know. Shouldn't there be a 6mm screw in there? :)
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline s7paul
« Reply #8 on: May 15, 2015, 07:04:57 PM »
I bought an Electrex RR24 for my 500 when I restored it.  That was 11 years ago, and it's been fine so far.  They're currently £78, so slightly more than the DSS item.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #9 on: May 16, 2015, 01:16:09 AM »
...yea yea yea, I'm mortified. But it was a 1/2 way house fix prior to getting OEM parts / set up ... which is where the bike is now. All luverly..
But ya should have seen it when I got it....
« Last Edit: May 16, 2015, 01:21:35 AM by Lobo »
  • 1977 CB550F2
« Reply #10 on: May 16, 2015, 02:14:16 AM »
£78? I bet there is something much cheaper around.
I had a Kwak triple. I remember the price exactly back in 77. £3.10 plus vat for points, 3 off. Mate worked at a Colt (Mitubushi) dealers and I got them for 99p.
Offline Spanner1972
« Reply #11 on: May 17, 2015, 08:59:07 AM »
Hi Spanner,
Job done.
Simon
Thanks for that. That's another bit of the jigsaw complete.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #12 on: May 18, 2015, 03:52:35 AM »
Hi again,
Bit of a brain fart - you'll only have a redundant green from the old regulator. The remaining Black & the White from the old regulator will connect into your new all in one unit.
I'm sure you've been keeping an eye on Nim's thread
http://www.sohc.co.uk/index.php/topic,8334.msg55264.html#msg55264
Simon.
Offline Spanner1972
« Reply #13 on: June 01, 2015, 08:27:20 PM »
Sorry another amateur question from me, I have all the electrical system on the engine. Starter, points, alternator. I have a loom but as I'm doing a bobber/chopper I'm not using indicators so I'll have cable spare. The question I have is, am I right in thinking all I need is the rectifier/regulator and I'm good to go?? I must be missing something.  :o
Thanks.
« Reply #14 on: June 01, 2015, 09:28:09 PM »
You don't need the flasher relay, grey wire to the handlebar switch, light blue,  orange, light blue /white and orange/white wires plus a load of spare green wires to the indicators.
