The carbs on the K "I think" are shorter than the PD's so modification's around the air box would be required to make it fit. Also seen the thread discussing larger idle jets but cant find it again now. That would probably do it as it's the lean mixture causing the problem, no idea where you would get a non standard item like that though.
