Author Topic: Cam chain tensioner.  (Read 1677 times)
« on: June 04, 2015, 06:00:19 PM »
Can someone in the know have a quick look at these pictures and say if this tensioner blade is shot or re-usable. I think it's past it's best? Also, are the aftermarket tensioners any good or am I best with genuine. Thanks in advance.
Re: Cam chain tensioner.
« Reply #1 on: June 05, 2015, 06:52:26 AM »
As long as the rubber is not peeling off at the ends that is fine, a new one will look like that in a few 1000 as the chain side plates wear into the rubber till the rollers touch
« Reply #2 on: June 05, 2015, 07:18:56 AM »
Thanks Bryan. Looks fine except for the grooves. Will reuse it then.
Offline exvalvesetdabbler
« Reply #3 on: June 21, 2015, 01:02:52 PM »
The shop manual p77 gives 4mm new and 3.0mm service limit measured in the center for the tensioner
Dave.
« Reply #4 on: June 22, 2015, 07:18:49 AM »
Dave.
Don't believe everything you read in a book. That blade is fine  ;)
Offline ka-ja
  • ken
  • yoshi 460
« Reply #5 on: June 22, 2015, 11:18:02 AM »
Hi,
    Make sure you check for small cracks in the rubber slippers, I have had that "age" fault on original tension blade at 38,000 miles.
nice bike,nothing in the bank
