Author Topic: Holes in the fuel tank  (Read 12006 times)
Offline El__burro
« on: August 10, 2015, 08:55:32 AM »
Good morning, last night i received a slap on my face when I noticed the 2 tiny holes in my fuel tank.
I guess by removing the paint a bit I'll find some more.
Any ideas on what is best to fix this.
I have seen some paste to close the holes, any good? Any brand?
Good day
El__Burro
Offline stevush
Re: Holes in the fuel tank
« Reply #1 on: August 10, 2015, 09:20:43 AM »
It might sound crazy but it could be welded. I've seen it done before by a chap who filled the tank with water first. When full of water there are no fumes to ignite so although I wouldn't risk it personally it can be done if caution is observed. In your case the holes are underneath and not seen so maybe worth considering?
Steve
Offline El__burro
« Reply #2 on: August 10, 2015, 09:59:10 AM »
I did consider that option but only if no other solution is better.
Welding could perforate the material.
Tank needs to be sealed so been washed out already.
Thank you
el__burro
Offline mike the bike
« Reply #3 on: August 10, 2015, 10:35:04 AM »
I've had that problem too.  I brazed plates over the bottom of the tank but 2 further problems arose;
More holes appeared because the bottom of the tank is as thin as foil.
The rust has a tendency to block the fuel filter.
I used a (modified) Superdream tank until I found a replacement in a breakers but I would consider a tank lining kit, but don't ask me which is the best.
Offline El__burro
« Reply #4 on: August 10, 2015, 10:37:43 AM »
noooooo.
lets stay positive.
« Reply #5 on: August 10, 2015, 10:39:30 AM »
I just don't want you wasting your time brazing, welding or filling holes.
Offline csd4t
« Reply #6 on: August 10, 2015, 11:29:39 AM »
I have used some epoxy type stuff (not sure of the name) to plug a leak on a fuel tank and then done all practice week and 2 x 3lap sidecar races at the Isle of Man without a problem, and thats with 45 litres on board.
There is no F in cod
« Reply #7 on: August 10, 2015, 12:27:48 PM »
No matter how many holes you plug up there's always another one, and you still get fuel starvation from the rust blocking the filter.   Been there, done that.....
Offline Green1
« Reply #8 on: August 10, 2015, 07:35:31 PM »
Same here you think its sorted then months later your lovely new paintwork is fucked  :-[ were its sprung another leak.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline captaink
  • Old racers never die. ' they just go faster '
« Reply #9 on: August 10, 2015, 07:50:52 PM »
I have been there with restorations , in the end I have had the tank shot blasted then you can see the real extent of the holes, these can be brazed and after checking with a gallon of white spirit (not water) that there's no leaks use a tank sealer kit say from frosts restoration or similar.
After that have the tank painted. Nothing worse than fuel leaking when your out on a run somewhere.
No real cheap fix.
Either that or find a new tank somewhere
Good luck....
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline captaink
« Reply #10 on: August 10, 2015, 07:55:08 PM »
By the way, you can wash out the tank with a degreaser and cleaner, frosts do them.
They won't smell of fuel and you will get someone to braze or weld it.
If it smells they won't want to weld it.
'BOOM'
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline RGP750
« Reply #11 on: August 10, 2015, 08:43:00 PM »
I Have a tank spare here if interested.
Just pm me with a phone number.
Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline El__burro
« Reply #12 on: August 12, 2015, 09:30:00 AM »
here is the tank bottom after sanding it for 5 minutes.
i am sure more washing will bring more holes.
is mig welding any good?
regards
el__burro
« Last Edit: August 12, 2015, 09:31:38 AM by El__burro »
« Reply #13 on: August 12, 2015, 12:07:22 PM »
I reckon you would blow holes if you try to mig weld it, even on a low current. I would consider Rich's offer of a replacement if it was me. You will forever be wondering if more holes will develop if you weld/braze it plus it could ruin a very expensive paint job if it does.
Ash
« Reply #14 on: August 12, 2015, 02:14:44 PM »
I recon that will come up OK, if brazed. Seeing I am next in line on Rich's tank  ;D ;D ;D
