Author Topic: CR 750 FORKS  (Read 2090 times)
Offline captaink
  • Old racers never die. ' they just go faster '
CR 750 FORKS
« on: August 24, 2015, 05:58:35 PM »
Hi, I'm considering what forks would be best suitable for my CR 750 Replica build
They need to look in character with the period and be suitable for twin disks
Any suggestions appreciated !
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
CR 750 FORKS
« Reply #1 on: August 24, 2015, 07:43:36 PM »
A lot of the US guys use early GL1000 forks....I have a few sets if interested...nice feature is the 38mm stanchions so a bit stiffer than std 35mm - and the triple stem is same design as the 750
« Last Edit: August 24, 2015, 07:57:04 PM by Jamesh_sussex »
Re: CR 750 FORKS
« Reply #2 on: August 24, 2015, 07:44:29 PM »
This is Mikeb4's example...
Re: CR 750 FORKS
« Reply #3 on: August 24, 2015, 10:46:08 PM »
I really like that - James, you mentioned Gold Wing forks - do you use 750 yokes bored to 38mm or do the Gold Wing yokes go straight onto the 750 frame?
Re: CR 750 FORKS
« Reply #4 on: August 24, 2015, 11:12:55 PM »
And who makes those exhausts?
Re: CR 750 FORKS
« Reply #5 on: August 25, 2015, 12:53:05 AM »
Yeah std gl1000 triple tree. Those pipes are actually cut down cb750 k7/8 sankei pipes...
Re: CR 750 FORKS
« Reply #6 on: August 25, 2015, 12:54:41 AM »
Offline captaink
Re: CR 750 FORKS
« Reply #7 on: August 25, 2015, 08:21:54 AM »
Thanks James, the gl forks have the calipers rearward facing and the originals were front facing.
Small thing I know but this is the reason I asked.
The gl forks... Do they need new trees or do the fit straight on the cb headstock ?
I saw a conversion fork stem that adapts to the cb ... What's the set up ?
On my other CR I have marzochi forks with front facing calipers
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Re: CR 750 FORKS
« Reply #8 on: August 25, 2015, 09:28:34 AM »
Probably best to try and source / replicate what you have if you need the front facing calipers. Or source a std Uk twin disc 750 setup. Gl1000 triples are a straight fit on the 750 headstock - would suggest new bearings.
