Author Topic: Fuel petcock repairable?  (Read 4894 times)
Offline Noelia
« on: September 27, 2015, 07:45:06 PM »
Hi all,
My fuel petcock is missing the long tube I don't really know what's the functionality?
Thanks!!
Offline haynes66
Re: Fuel petcock repairable?
« Reply #1 on: September 27, 2015, 08:02:19 PM »
the long tube is there to give you a reserve amount of fuel. you can ride without it but you no longer have any reserve.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline Noelia
« Reply #2 on: September 27, 2015, 08:26:13 PM »
I see! I need a reserve... Can't ride without it Is there anyone in the forum that have a spare one I will be interested!
Online AshimotoK0
« Reply #3 on: September 27, 2015, 09:06:28 PM »
In have some brass tube at work need to check the diameter though.
Ash
Offline Noelia
« Reply #4 on: September 27, 2015, 10:03:54 PM »
Ash
Hi Ash, that would be great, do you know the right diameter?
Noe
Online AshimotoK0
« Reply #5 on: September 27, 2015, 10:27:52 PM »
i will try & find out for you.
Online AshimotoK0
« Reply #6 on: September 28, 2015, 07:28:02 AM »
The magic of the USA Site sohc4.net forum  :)  Not sure if he didn't measure diameter  on the wrong bit of the calipers though. Comments please?
I have some 5mm dia brass, I will make you one .. may take a day or so though.
cheers ... Ash
« Last Edit: September 28, 2015, 07:37:54 AM by AshimotoK0 »
Offline mike the bike
« Reply #7 on: September 28, 2015, 07:42:26 AM »
Oh dear, not the way to use calipers.
Online AshimotoK0
« Reply #8 on: September 28, 2015, 09:18:23 AM »
Wonder if it's actually 5mm?
Offline gtmdriver
« Reply #9 on: September 28, 2015, 10:19:46 AM »
When I stripped my CB350F fuel tap the reserve tube came off in my hand.
It seemed to have a taper fit so I used high strength Loctite and pushed it back in gently with my vice.
So long as the petrol doesn't dissolve the Loctite I'll be fine.
Offline Menno
  • www.tanklackieren.de
« Reply #10 on: September 28, 2015, 11:11:10 AM »
Ah, Noelia, too bad I just read this post now. Ik have buckets full of these fuelcocks. If I would have known earlier I would simply have put it in the package with the tank.
Well... if you still need one you can have it.
Offline Noelia
« Reply #11 on: September 28, 2015, 12:24:14 PM »
Hi Menno!
Such a shame!! I didn't know that, I do appreciate that seriously! You're great!
Offline Noelia
« Reply #12 on: September 28, 2015, 12:26:27 PM »
cheers ... Ash
(Attachment Link)
(Attachment Link)
Hi Ash!
No worries For time i still have a week or so to finish the petcock, I appreciate very much your help!
Thanks!
Offline MCTID
« Reply #13 on: September 28, 2015, 02:06:03 PM »
Just measured the Petcock on my 1974 CB750K4 US model. I cannot see it being different from the 500/550.
The Outside Diameter (O/D) is 5.5mm.
The wall thickness is 0.6mm.
The tube protrudes into the tank for a distance of 64.6mm (at the longest point - its angled).
Cannot measure how far into the body of the Petcock it is inserted as it's brazed in - but if you allow 25mm you won't go wrong and can cut it off later to give you the 64.6mm length you need when finished.
Measured using my cheapo Digital Caliper.
Offline Noelia
« Reply #14 on: September 30, 2015, 11:24:03 AM »
Great info!!!
