Author Topic: Head gasket  (Read 2969 times)
Offline yozzer74
Head gasket
« on: November 12, 2015, 05:19:23 PM »
Would anyone say it's worth buying this head gasket over the head gasket you get in David silver's gasket set . [ Guests cannot view attachments ]
Offline bytio
Re: Head gasket
« Reply #1 on: November 13, 2015, 01:40:35 AM »
Yes it would, the genuine Honda gasket is far better than copies and will greatly aid the prevention of oil leaks!
Re: Head gasket
« Reply #2 on: November 13, 2015, 08:43:44 AM »
It doesn't say that it is a Genuine Honda gasket, it states NOS! which could refer to any new old stock and the part number could be used as reference only. Lots of people listing parts like this on fleabay.
Offline UK Pete
Re: Head gasket
« Reply #3 on: November 13, 2015, 05:47:22 PM »
IT HAS THE CORRECT OVAL FIRE RINGS AND THE SEALANT ROUND THE CAM TUNNEL, SO IT COULD WELL BE HONDA, IF SO I WOULD BUY IT IF I WERE YOU, SEND THE GUY A MESSAGE AND ASK
PETE
Offline bytio
Re: Head gasket
« Reply #4 on: November 13, 2015, 06:30:29 PM »
I think it is the genuine one,
Offline yozzer74
Re: Head gasket
« Reply #5 on: November 13, 2015, 07:50:41 PM »
I've bought it we will find out. should have asked first I suppose .
Offline yozzer74
Re: Head gasket
« Reply #6 on: November 13, 2015, 07:55:29 PM »
It does say genuine in the description
Offline Chris-freckle
Re: Head gasket
« Reply #7 on: November 13, 2015, 10:29:26 PM »
Hi I may be a bit old fashioned but I would not use anything other than genuine Honda gaskets unless Comedic ones are available.
Re: Head gasket
« Reply #8 on: November 14, 2015, 09:06:10 AM »
Never seen funny gaskets but have seen cosmetic (i think you mean cometic)
Offline bytio
Re: Head gasket
« Reply #9 on: November 14, 2015, 12:28:14 PM »
Here is the genuine gasket about to be buttoned up
Offline yozzer74
Re: Head gasket
« Reply #10 on: November 14, 2015, 12:31:53 PM »
Do you use any sealant on your base gasket
Offline bytio
Re: Head gasket
« Reply #11 on: November 14, 2015, 11:19:29 PM »
No never used it on base or head gasket, make sure you use genuine Honda o rings as pattern ones are not thick enough and could get leaks. Also on the head, make sure the cam tower stud threads are sealed with thread sealant as some holes lead to the outside, was caught out by this on one rebuild and had to pull engine to redo.
Offline bytio
Re: Head gasket
« Reply #12 on: November 14, 2015, 11:24:32 PM »
Offline bytio
Re: Head gasket
« Reply #13 on: November 14, 2015, 11:24:50 PM »
These are the ones I mean
Offline yozzer74
Re: Head gasket
« Reply #14 on: November 15, 2015, 12:03:57 AM »
Which ones the ones with the nuts on
