Just thought I would ask about the assembly of the crankcase halves on a CB750.
I always assemble the crankshaft into the top casing along with the mainshaft, primary chains, and output shaft. But just noticed that the Haynes manual says to assemble it all in the bottom casing, and the Clima manual says to do it my way.
Which is the correct way to do it?
Cheers.
