Author Topic: brake lines .... are braided steel worth it here?  (Read 1961 times)
Offline Skoti
Re: brake lines .... are braided steel worth it here?
« Reply #15 on: August 28, 2021, 09:20:30 AM »
Here's the Goodrich fitting that goes in the mudguard wire loop and grommet.
This is similar to what I used to keep the original caliper hard line.
https://www.goodridge.co.uk/collections/jic-unf-re-usable-fittings-for-600-series-hose/products/jic-zinc-plated-steel-metric-fixed-female-with-two-circlip-grooves-convex-seat
1976 Honda CB750F1
« Reply #16 on: August 28, 2021, 09:24:06 AM »
Hi, Skoti.
Thanks for that, but I’m talking about the mudguard wire loop that holds the rubber grommet on the original hard lines.
Offline Skoti
« Reply #17 on: August 28, 2021, 09:49:45 AM »
Sorry,
my heads a bit fuzzled, too much bier last night...
I would probably chop a wire loop from an old mudguard and attached a small bracket to it, then drill and fit to the mudguard brace with a couple of nice 4mm original Honda JIS set screws.
It'll be interesting to read what others do tho.
Good luck
Skoti
1976 Honda CB750F1
« Reply #18 on: August 28, 2021, 10:01:10 AM »
Unfortunately using the original won’t work as it’s ‘handed’. But yes, interesting to learn what other do.
Offline 4wDaz
« Reply #19 on: August 28, 2021, 10:52:15 AM »
Looks like a full set of hoses for my F2, front and rear come to £132 with VAT.
Thats in plain black with plain stainless fixings
Hel and Goodridge are pretty much the same pricewise, to within a couple of £££.
Seems expensive, are they standard length and fittings ?
Genuine And Aftermarket Motorcycle Parts Supplier
Offline SumpMagnet
« Reply #20 on: August 28, 2021, 11:01:55 AM »
standard length and fittings....but that's a twin disc front setup with 3 hoses... plus a rear hose and fittings.
I want to keep the stock hose pattern with the single hose down to the joining block...then seperate hoses to the 2 front calipers.
CB750F2 - in pieces
Offline Skoti
« Reply #21 on: August 28, 2021, 11:31:23 AM »
Just dug out the fleabay receipt for my Goodridge stuff.
BG Supplies are a lot cheaper than buying direct from Goodridge, £10.45 for a metre of hose and £5.00 - £10.00 for fittings.
Here's a fleabay link to their stuff:-
https://www.ebay.co.uk/sch/i.html?_nkw=&_in_kw=1&_ex_kw=&_sacat=0&_udlo=&_udhi=&_ftrt=901&_ftrv=1&_sabdlo=&_sabdhi=&_samilow=&_samihi=&_sadis=15&_stpos=TD60PL&_sargn=-1%26saslc%3D1&_salic=3&_fss=1&_fsradio=%26LH_SpecificSeller%3D1&_saslop=1&_sasl=bg-supplies&_sop=12&_dmd=1&_ipg=50&_fosrp=1
1976 Honda CB750F1
« Reply #22 on: August 28, 2021, 02:07:34 PM »
Thanks oddjob. Did you reverse bend the wire loop of just use it upside down?
