Author Topic: Gammatronics  (Read 956 times)
Offline oldboy
Gammatronics
« on: April 04, 2024, 02:13:37 PM »
Has anybody fitted this Gammatronix condenser replacement/spark booster. Did it make any improvements at all??
Online McCabe-Thiele (Ted)
« Last Edit: April 04, 2024, 06:46:30 PM by McCabe-Thiele (Ted) »
Re: Gammatronics
« Reply #2 on: April 04, 2024, 05:21:21 PM »
They make "supplementary" switching kits, much like Hondaman type unit, this to take triggering from points and then switch load to coils by solid state circuitry.
Unsure if that's what is meant in enquiry  ....
If that's the case, it looks reasonable, but would need a field test pilot  :) to give us a view of practicals here on the forum.
Re: Gammatronics
« Reply #3 on: April 04, 2024, 06:57:59 PM »
Looking at the system blurb it looks like a half way house between a full electronic system & normal points.
One criticism of Dyna & other system like DS sells is the current draw. Looking at the downloadable fitting instructions & item details there is no mention of how much power the unit uses unless i have missed it.
Compared to the Dyna system its also quite bulky but the cheaper price offsets this so it has some merits as you remove the condensers.
Offline Seabeowner
Re: Gammatronics
« Reply #4 on: April 04, 2024, 07:01:15 PM »
One per points/coil set. But this is OOS.
https://www.ebay.co.uk/itm/191717401937
So only two singles available.
Searched gammatronics and this cam up, so may have a go at a couple.
https://quasarelectronics.co.uk/Item/velleman-k2543-electronic-transistor-ignition-kit
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Re: Gammatronics
« Reply #5 on: April 04, 2024, 08:21:06 PM »
The Vellman kit has been about for decades, more meant for a car but will work just need 2
Re: Gammatronics
« Reply #6 on: April 05, 2024, 12:29:30 PM »
Made my own transistorized EI over 20 years ago. Ultrarelaible. A shameless copycat of the Velleman x2. In practice: some but noticeable improvement near idle and over 6000 rpm, midrange the same as OEM. Breakerpoints live forever. Mine already over 60.000 km. If you want to learn more, you may want to read: http://forums.sohc4.net/index.php/topic,188940.msg2195751.html#msg2195751
BTW, can AI or whatever app play the cited video (Youtube) with English subtitles?
« Last Edit: April 05, 2024, 12:42:56 PM by deltarider »
Offline oldboy
Re: Gammatronics
« Reply #7 on: April 06, 2024, 02:17:03 PM »
[/quo
They do a twin coil set up.
