Author Topic: CB750 F1 Fuel Tap  (Read 3694 times)
Offline r1_pete
CB750 F1 Fuel Tap
« on: May 28, 2012, 11:36:47 AM »
Hi All, does anyone know if there fuel taps from other Honda models which will fit the F1 tank with the 20mm threaded fitting? F1 taps seem few and far between and mine is broken off at the gland nut flange, and the nut is missing.
Cheers.
Pete.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Re: CB750 F1 Fuel Tap
« Reply #1 on: May 28, 2012, 11:50:09 AM »
The same tap is fitted to the CB750 K5 and K6, but thay are the only bikes I know of with the same tap, for whatever reason Honda put a smaller threaded tap on the F2! I may have a spare tap on a rusted through tank in my store room, I'll take a look later ;D
Offline kifer
« Reply #2 on: May 28, 2012, 01:11:41 PM »
Hi Pete, If you have no luck in finding one maybe this will help, I have used mostly on ally tanks but should work on yours, compressor fittings cheep to buy and you can go up or down on sizes then buy a cheap tap with filter or use an inline, I also tend to use thread seal. Might get you out of the poo if you can't find original.
Offline bluemouse1006
« Reply #3 on: May 28, 2012, 10:20:23 PM »
Hi I had the same problem with my K5 looked every where and nothing seemed to fit so had to go to Dave Silvers in the end and spent the thick end of £58 for it .. Very painfully to the old bank balance but it ad to be done !
Amoshttp://
Amos
Offline r1_pete
« Reply #4 on: May 29, 2012, 08:11:46 AM »
Thanks All, does anyone know what the thread is, it looks like M20 x 1.5, but as usual I lent a mate my thread gauge, so can't be sure of the pitch.
Cheers.
Pete.
1971 CB450
« Reply #5 on: May 29, 2012, 08:18:42 AM »
I found the tap, it could do with a filter kit (£16 from DSS) if you pm me your name/address I'll pop it in the post to you
Offline Tomb
« Reply #6 on: May 29, 2012, 08:02:53 PM »
Cheers.
Pete.
Sounds like you're sorted, buuuut if you're ever short of a thread gauge use a bolt you know the pitch of, i.e. a standard M10 has a pitch of 1.5mm, slide that up against the (suspected) M20 for a gauge.
Same with any other fine thread bolts you want to measure, use a smaller known thread bolt for a gauge.
e.g. Is it an M10 fine thread on your bike, what pitch?? 1.25mm, 1.0mm. Does a standard M8 fit into the thread nicely or a standard M6?  Standard M8 pitch is 1.25mm, M6 - 1.0mm.
HTH
Sorry, my engineer OCD kicking in, I'll get me coat  :-X
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
