Author Topic: Bike won't start - help!  (Read 48954 times)
Offline JustcallmeMrT
Re: Bike won't start - help!
« Reply #30 on: May 31, 2016, 04:30:09 PM »
Hold it. If your coils happen to be the (green?) 3 Ω coils like mine the last thing you need is a relay. This whole relay hype crossed the Atlantic I'm afraid and I doubt there will be any advantages to speak of.
I'm running the 5 ohm coils.
Sent from my SM-N9005 using Tapatalk
« Reply #31 on: May 31, 2016, 04:30:32 PM »
Made a big differance on my Z650 ;D
« Reply #32 on: June 02, 2016, 10:05:37 AM »
Well, think I found my issue.  Borrowed a compression tester and it's down to 110 psi on each cylinder, and should be 170 psi, correct?
Something has definitely gone wrong.
Offline deltarider
« Reply #33 on: June 02, 2016, 11:35:10 AM »
Quote
Don't panic. I myself never managed to succesfully do a compression test on my CB500. Outcome was always way too low. Moreover, not every compression tester is suitable for the job. Hence my oldfashioned way of testing. Thumb (or finger) over sparkplughole, let somebody kick the engine. Thumb blown of: compression is fine. Thumb still on the hole: compression not good.
Offline tom400f
« Reply #34 on: June 02, 2016, 12:06:45 PM »
Read through this thread a couple of times... can we recap/confirm a bit of history:
1. you were riding it regularly a decent distance
2. one day you walked up to the bike cold and it wouldn't start?
3. any spluttering/it tried to fire but couldn't get going? Or completely dead not even a cough?
4. it was a sudden and unexpected onset?
5. Re compression - does it "feel ok" on the kickstart (so empirical like deltarider is saying)? Unlikely that all cyls would suddenly report low values...
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline hairygit
« Reply #35 on: June 02, 2016, 12:32:38 PM »
Did you hold the throttle wide open with choke off doing the compression test?
« Reply #36 on: June 02, 2016, 12:50:47 PM »
Yes
[/quote]
2. one day you walked up to the bike cold and it wouldn't start? [/quote]
It became a bit harder to start over a couple of days, then no start at all.
[/quote]
3. any spluttering/it tried to fire but couldn't get going? Or completely dead not even a cough?  [/quote]
It does cough occasionally, and yesterday night randomly started up once but died as soon as I let the revs drop.  Wouldn't start again.
[/quote]
4. it was a sudden and unexpected onset? [/quote]
Harder to start over the course of 3-4 days.
[/quote]
[/quote]
Feels fine via kicking it over - I haven't noticed a change.
« Reply #37 on: June 02, 2016, 12:51:28 PM »
Not WOT... will re - test.
Offline hairygit
« Reply #38 on: June 02, 2016, 12:53:24 PM »
Throttle needs to be wide open, needs air to go into the cylinders in order to compress!
« Reply #39 on: June 02, 2016, 04:55:11 PM »
With no choke and WOT I get 130 - 135 psi per cylinder.
« Reply #40 on: June 02, 2016, 04:55:38 PM »
Try draining the float bowls, unlikely but possible they could have water in them. When I was syncing carbs I'd have a small bottle full of petrol suspended from the bars, the petrol was a known quantity then not something that may have been contaminated in the tank. I used a 2 stroke tank off a small Yamaha as they have spouts on the bottom so easy to get a fuel line on them.
Drained them yesterday... Unfortunately no luck.
« Reply #41 on: June 07, 2016, 06:19:59 AM »
Well, it's running again.  I was wracking my brain for anything I'd done differently before it all went wrong and realised I'd topped off the tank with premium instead of my usual regular petrol.  In an off chance I got a jerry can of regular, drained the carbs and hooked up an auxiliary tank, and it fired second kick.  Started 5 more times after that, so hopefully problem solved.  Still doesn't make any sense though.
Offline hairygit
« Reply #42 on: June 07, 2016, 06:40:57 AM »
Some garages do sell dodgy or contaminated fuel, and supermarket garage seem to be the worst offenders. I have also known fuel delivery tankers put fuel in the wrong storage tanks, ie. Petrol in diesel tanks....  Glad it seems to be sorted!
« Reply #43 on: June 07, 2016, 07:26:28 AM »
That is strange because it should of fired on easy start in that case.
« Reply #44 on: June 07, 2016, 08:12:10 AM »
Well, it won't start again this morning.  If someone offered me a damn moped in trade I'd have to consider it at this point.  I'm done.
