Author Topic: Tappet adjustment  (Read 2980 times)
Offline Beddgelert
Tappet adjustment
« on: June 03, 2016, 06:04:31 PM »
I was wondering if I could beg some advice please?
I have just rebuilt the top end of my engine and I am finishing off by setting the tappets. I have set cylinders 1 and 4 to the correct tolerances but when I try to adjust the tappet screws on 2 & 3 the valve seems to follow the adjustment screw as I loosen it even to the point when I take the screw out completely I can't get the gauges between the rocker arm and the top of the valve?
I've kind of left it for a beer and a head scratch but wondered if I've missed something obvious before taking the rocker cover off again?
« Last Edit: June 03, 2016, 06:11:36 PM by Beddgelert »
CB 550 KO
Re: Tappet adjustment
« Reply #1 on: June 03, 2016, 08:42:23 PM »
try this video
  hope it helps
https://www.youtube.com/watch?v=bLw6Av07wik
« Reply #2 on: June 03, 2016, 10:03:18 PM »
You need it on "T" 2&3 to do the tappets on 2&3.
Offline Beddgelert
« Reply #3 on: June 04, 2016, 08:21:56 AM »
Thanks John, it was a great help. The mistake I was making was that I was working on the rong set of tappets I looked for cylinder 1 to be tight at TDC and in fact they should have been loose before starting. Anyway all sorted now
CB 550 KO
