Author Topic: Battery reads 15.4V  (Read 2731 times)
Offline ginger_jim
  • Anyone for a Guinness?
Battery reads 15.4V
« on: June 09, 2016, 07:52:01 AM »
Hi all, thought i'd check my battery voltage yesterday and got the above reading.  Battery is a year old and visually looks good, Dave Silver 'MF' from memory, spent the winter being plugged into an optimate for 24 hours once a week and insulated against the cold.  I instantly though dodgy meter, so I checked my beemer battery which has been maintained the same way (its an odyssey) and it gave a similar reading.  Went and checked my van battery and it read 13.4 volts.
Anyone had similar experiences?  Could the optimate be on the way out and both batteries are toast?  :'(
Online SteveD CB500K0
Re: Battery reads 15.4V
« Reply #1 on: June 09, 2016, 08:36:40 AM »
That's too high. Even on charge it should only reach 14.6 or 14.7V.
Is that open circuit?
Steve
Offline ginger_jim
« Reply #2 on: June 09, 2016, 10:16:31 AM »
Hi Steve, I apologise for my ignorance but im not quite sure what you mean :-)
« Reply #3 on: June 09, 2016, 11:38:45 AM »
Steve means (i think) is that is the meter reading with both leads from the bike loom / earth cable removed (i.e. with the batter disconnected from the bike).?
Offline ginger_jim
« Reply #4 on: June 09, 2016, 12:05:36 PM »
No, that's with everything connected.  The more I think about it the meter must be at fault. Ill borrow another meter to double check.
« Reply #5 on: June 09, 2016, 03:13:17 PM »
If it reads that without the engine running your meter is wrong, most I ever seen is 14.8 and falling quickly just after taking off a big(but very controllable) charger
« Reply #6 on: June 09, 2016, 08:26:17 PM »
I've rarely seen any automotive 12v battery anything much over 13v without any outside input, so something is odd.
Optimise 6 can pulse to something toward 17v I understand so has some potential to get into that range if that's what you are using.
Offline ginger_jim
« Reply #7 on: June 10, 2016, 07:42:20 AM »
Panic over...dodgy meter was to blame  ;D
