Author Topic: CB250G5 / 360G5 seat lock bracket measurements  (Read 2927 times)
Offline boxie30
« on: June 15, 2016, 07:34:18 AM »
Hi all,
Does anyone own a CB250G5 or CB360G5?
Was given a 250 in boxes and have been slowly putting it back together.
I have just realised that my newly painted frame is missing the seat lock bracket, would it be possible for someone to give me some measurements of the bracket so i can get a new fabricated.
Cheers.
Re: CB250G5 / 360G5 seat lock bracket measurements
« Reply #1 on: June 15, 2016, 09:34:42 AM »
Welcome !
Not sure..the seat latch is the same as the 400/4 I think and possibly CB250/350K4 . DK Spares are bound to have one from a USA CB360G
Genuine Service manual is here on this site BTW.
SEARCHABLE CB360 G5 SERVICE MANUAL
https://www.dropbox.com/s/mcug2pb5eaj6ydq/CB360_Searchable_Manual.pdf?dl=0
 May be worth joining and asking on HondaTwins.net  site (I am member there too)
JamesH on here has some parts in Member Sales inc a seat
http://www.sohc.co.uk/index.php/topic,10158.0.html
cheers ... Ash
« Last Edit: June 15, 2016, 09:37:09 AM by AshimotoK0 »
Offline boxie30
« Reply #2 on: June 15, 2016, 12:48:35 PM »
Ash,
Thanks for the reply.
It is the dimensions of the actual bracket that i am after or the bracket itself!
Just done an internet search on the frame for the 400/4 and the bracket does look the same.
Would need to find a damaged one so i can cut it off and get it welded to mine.
Off to join HondaTwins.
Michael.
Offline Chris400F
« Reply #3 on: June 15, 2016, 04:50:39 PM »
As Ash says the latch is the same as the 400/4. It is a 340 part number, not sure what model 340 relates to (but Ash may well know!).
I should be able to get dimensions and photos of the bracket for you. It will be tomorrow as I will have to move stuff around in my garage to get access.
« Reply #4 on: June 15, 2016, 05:21:58 PM »
340 centre no. = SL350K2
Offline Chris400F
« Reply #5 on: June 17, 2016, 09:51:15 AM »
OK, had a look at the bracket on my bike. It's a sod to get the shape, probably easiest to use a lock to get the right edge shape as the profile is the same.
There is a protruding lug on the underside which locates in one of the holes on top of the lock so not easy to trace the outline.
A selection of photos of the bracket, plus some possibly useful dimensions.
Diameter of lock plunger hole: 17mm, tapering out to 22mm on top.
Thickness of bracket: 4mm
Edge of shock absorber mount to centre of plunger hole: 113mm
Edge of frame tube to centre of plunger hole: 20mm
Top of bracket to bottom of frame tube: 4.5mm
Hope this gives enough information for a start at least. I'll try and help more if you need it but will be away for the next week.
Offline Chris400F
« Reply #6 on: June 17, 2016, 09:52:31 AM »
And a couple more pics (can only put 5 in a post).
Offline boxie30
« Reply #7 on: June 20, 2016, 04:06:41 PM »
Chris400F
Thankyou very much for the information and pictures, that certainly gives me a start.
Looking at them, the bracket looks the same as the outline for the lock. Which helps as well.
Cheers.
