Bottom End Rebuild
Topic: Bottom End Rebuild (Read 4388 times)
chunterjam
Newbie
Bottom End Rebuild
June 24, 2016, 04:55:49 PM »
Folks,
I've stripped my engine down this far to check the PO hadn't butchered the bottom end like he had most of the rest of the bike. Luckily it looks pretty good.
However, seeing as I'm this far...is there anything I should change before rebuild?
Re: Bottom End Rebuild
June 24, 2016, 06:21:22 PM »
Looks like a 500 so change the primary chain as there is no tensioner and the chain eats into the main oil gallery also the 8 damper rubbers in the primary drive to help the chain, then just a seal kit and maybe a cam chain
chunterjam
Newbie
June 24, 2016, 06:49:17 PM »
Sorry...should have said its a 550 :-) Thanks Bryan
June 25, 2016, 11:32:31 AM »
550 primary chain does not hit the cases quite as bad but still worth changing with the other stuff
Ashdowner
SOHC Expert
July 12, 2016, 07:21:09 AM »
Where are these rubbers on the primary drive Bryan? Is that anything to do with the clacking that many of us get on tickover?
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Trigger
July 12, 2016, 07:28:41 AM »
The rubbers are not on the primary drive but, in the drive.
July 12, 2016, 04:20:29 PM »
The rubbers are inside the primary drive gear on the primary shaft, the big lump the chain drives and has the starter clutch on it, the clanking is usualy the primary chain if the carbs are not in sync
Bottom End Rebuild
