Author Topic: Wanted - Recommendations for Vacuum Balance Gauges (CB750F1)  (Read 14597 times)
Offline Zunspec
Hello,
I am after buying a set of vacuum gauges to balance the carbs on my CB750F1.  eBay has them priced from £33 to £150+ so plenty of choice but what ones are worth buying.  What makes have a decent reputation.
Cheers    Geoff
Offline Mr-Gear
Re: Wanted - Recommendations for Vacuum Balance Gauges (CB750F1)
« Reply #1 on: June 30, 2016, 01:33:28 PM »
Hi,
I don't have a great deal of experience. but I have the following:
http://www.ebay.co.uk/itm/Dellorto-Weber-Mikuni-Kehin-4-Column-Manometer-Morgan-Carbtune-Pro-carb-balancer-/262446445965?hash=item3d1b06f58d:g:OIIAAOxydUJTNXW6
Happy with the build quality, allowed me to balance my carbs fine (400/4).
thanks, Ryan
« Last Edit: June 30, 2016, 01:42:46 PM by Binman180 »
Offline ginger_jim
  • Anyone for a Guinness?
« Reply #2 on: June 30, 2016, 02:36:27 PM »
+1 for the Morgan carbtune pro.  Used mine loads and balanced a lot of my mates bikes too.
Online SteveD CB500K0
« Reply #3 on: June 30, 2016, 03:27:30 PM »
I had one of these once.
I didn't find it during my "Barn Clearance" but if I do, you can have it for a tenner plus shipping. There were never any adaptors for the carbs.
Steve
« Reply #4 on: June 30, 2016, 04:07:22 PM »
Whatever you buy make sure they are fitted with damper valves. The cheap ones (without dampers) bounce all over the place and are very hard to use. The needle will jump with every pulse of the engine. I use these and they work very well, although they are more the high end price wise.   http://www.demon-tweeks.co.uk/motorcycle/testing-equipment/sealey-carburettor-synchronizer-vacuum-mini-type-vs209
« Last Edit: June 30, 2016, 04:10:36 PM by royhall »
Offline flatfour
« Reply #5 on: June 30, 2016, 05:44:41 PM »
I have a Davida set. Very well made, in metal and have worked for me for some 15 years.
« Reply #6 on: June 30, 2016, 05:53:35 PM »
The sealy one is the one I bought last year as I had problems with my blue metal ones, I was lucky and paid less than £100 but very impressed with quality and they have all the adaptors plus decent hose. Nearest to genuine Honda workshop ones I have ever seen
Offline gtmdriver
« Reply #7 on: June 30, 2016, 08:38:38 PM »
I used a Morgan for my BMW Boxer and Moto Guzzi Cali III and it was accurate and easy to use. For my CB350F I bought a set of the cheap blue metal gauges with damper valves and they work fine too.
If you want to second guess your gauges you can always swap the pipes around after you've got a good balance to see if any of the readings vary significantly.
Offline Zunspec
« Reply #8 on: June 30, 2016, 10:12:03 PM »
Thank you for all your replies and suggestions.  I have plumped for this set, which I think are the Sealey ones. A good range of adaptors so hopefully will be useful for my other bikes too.
http://www.ebay.co.uk/itm/FAST-DELIVERY-ADVANCED-MOTORCYCLE-CARBURETTOR-Synchronizer-BALANCER-TOOL-KIT-/161596052168?hash=item259fe012c8:g:-8gAAOSwstxU2eal
Cheers  Geoff
Offline petermigreen
« Reply #9 on: June 30, 2016, 10:23:35 PM »
Be interested to know how you get on with your choice. I am also looking for a set.
Keep me posted please.
Peter.
Offline Zunspec
« Reply #10 on: June 30, 2016, 11:23:34 PM »
Peter.
Will do, Peter.  Once I have learnt how to do it ;D
« Reply #11 on: July 01, 2016, 11:04:46 AM »
can I suggest you get something like this ,
http://yambits.co.uk/rd125-auxiliary-fuel-tank-p-10299.html
 you will find it helpful,
 or make  something similar
Offline Zunspec
« Reply #12 on: July 01, 2016, 04:09:41 PM »
Thank you for the tips chaps, syncronising 4 carbs will be a new skill for me. I will see about getting a small header tank, I was going to cobble something up using a plastic petrol container but the proper job looks much safer ;D
Cheers  Geoff
jimv50
  • Guest
« Reply #13 on: July 01, 2016, 05:34:22 PM »
I however will be having a go at making something like this  ;D
Offline gtmdriver
« Reply #14 on: July 01, 2016, 09:00:17 PM »
I just used the standard tank with an extension fuel tube standing on a nearby box.
As Oddjob says balancing the carbs is the very last job after you've set up the ignition and the valve clearances.
