Author Topic: Gearbox set rings  (Read 3128 times)
Gearbox set rings
« on: August 23, 2016, 04:25:13 PM »
This may be pretty basic stuff, but bear with me, I was raised on British twins and other primitive technology.
I can see the point of the set rings in the gearbox, to stop things moving sideways, but is there just one per bearing? Does it go half in each case, or doesn't it matter?
I seem to be missing a couple, but before I go on a parts hunt I need to be sure of what there should be.
Re: Gearbox set rings
« Reply #1 on: August 23, 2016, 04:51:07 PM »
One per bearing .. may have spare if you need but would have to check.
« Reply #2 on: August 23, 2016, 05:04:15 PM »
A clue is they are called half rings ;)
