Project Board
My cb750 scrambler build. Restart
7
8
9
10
Topic: My cb750 scrambler build. Restart (Read 43946 times)
onethumb
SOHC Expert
Re: My cb750 scrambler build. Restart
Reply #105 on:
December 18, 2016, 10:57:00 PM »
I'll get the grey matter looking at it again tomorrow. I'll be sure to put it out there when I do. ( never thought of the the heat from the regulator)
"20 in a 40 is not safe driving"
onethumb
SOHC Expert
Reply #106 on:
December 19, 2016, 09:39:18 PM »
Ok so I've made a bracket and welded it to the side of the battery box for the regulator. What do you think?
With it like this I've got a load of room now for the m-unit and the wiring so that's made it an easy way to lift the tray to access the battery.
mike the bike
CB400F, Royal Enfield Interceptor.
Reply #107 on:
December 19, 2016, 10:16:23 PM »
It should get an adequate cooling draught by there.
onethumb
SOHC Expert
Reply #108 on:
December 19, 2016, 10:21:27 PM »
Thanks Mike That's good news. I never thought about it to Yozzer pointed it out. As a result it's actually turned out a better idea.
mike the bike
Reply #109 on:
December 19, 2016, 10:28:14 PM »
It's the same position as my GS650G, so it'll be fine.
onethumb
SOHC Expert
Reply #110 on:
December 20, 2016, 08:37:07 PM »
Well now the real fun begins.
Original wiring from battery backs is in really good nick but the front part......wtf!
onethumb
SOHC Expert
Reply #111 on:
December 20, 2016, 10:38:34 PM »
Need help already. So I bought a new solid state regulator from m&p (picture below). All the diagrams I can find show dohc regulator retro fitted. Can anyone help. I'm scratching my head.
Thanks.
mike the bike
Reply #112 on:
December 21, 2016, 08:46:22 AM »
3 x yellows are the ac windings on the alternator. Red and green are the pos and neg to the batt. The black and grey (white?) go the inside coil of the alternator, the excitor winding.
Hope this helps.
yozzer74
Reply #113 on:
December 21, 2016, 11:31:37 AM »
You won't be using any of the old harness will you ??
onethumb
SOHC Expert
Reply #114 on:
December 21, 2016, 10:53:06 PM »
Hi Mike. Thanks for the reply. It's the black and white that I'm stuck with. Is there a diagram to explain what your saying as I'm still a bit lost. I got in touch with the manufacturer and they sent me this.
Red. Positive
Green. Ground
Yellow. Stator
Black. Original sence input for regulator
White. Field output for alternator
Hi Yozzer, nope it's all going. Completely new.
mike the bike
Reply #115 on:
December 22, 2016, 07:48:21 AM »
Dunno what the original sense input is, sorry.
onethumb
SOHC Expert
Reply #116 on:
December 22, 2016, 07:56:31 AM »
Hi Mike, thanks anyway. I'm going to email them again and ask them to send me a diagram.
onethumb
SOHC Expert
Reply #117 on:
December 22, 2016, 08:06:28 AM »
This is the last email I got from them
mike the bike
Reply #118 on:
December 22, 2016, 08:19:24 AM »
It looks like it should also go to the battery, along woth the red, to sense the battery voltage - to measure if it needs charging or not. But that's only an educated guess.
onethumb
SOHC Expert
Reply #119 on:
December 22, 2016, 03:45:41 PM »
Hi Mike and anyone else interested in this, I've found this online. Does this make sense to you? It seems to work on paper but this is way above my knowledge. Knew I should of sent more time on electronic systems.
7
8
9
10
Project Board
